best way to hog out material on chair arm
fred in ct
>The rubber arms on my computer chair are shot and i'm replacing them with maple. Since i want to keep a concave area in the arm pads i'm trying to figure the best way to remove this material,ie:grinder, sander, spokeshave,etc.thanks
Re: best way to hog out material on chair arm
>All of the above depending on your skill level with that tool. I've used belt sanders, drum sanders, angle grinders with sanding discs, spoke shaves and drawknives. My choice if not removing much wood is the spokeshave. A drum sander on a flex shaft machine would be used to clean it up if needed but usually I get a surface that only needs light sanding.
For slightly more aggressive removeal I will start with the drawknife or use the belt sander with 36 grit belt.
For really aggressive removeal I use an angle grinder with a chainsaw cutter or a sanding disc with 24 grit paper.
Tony - Memphis
>I would just go at it with a carving gouge and clean it up with a scraper.
Tony
Thad
>Table saw with dado set, multiple passes raising or lowering the blade along the length of the curve, followed by progressive sanding with ros.
~ Thad
Drawknife, then spokeshave
>clean it up with a scraper or ROS.
Depends
>Depending on the depth of the concave curve, I'd probably start with a bandsaw, then round the corners and finally use spokeshave(s) to smooth and finish-sculpt the contours and edges.The final step would be a ROS, beginning with whatever grit was needed to have an effect on the remaining shave marks, unless I wanted them to stay as evidence of work.
Chainsaw w/24" bar
>Unless you want an excuse to buy more tools.
Clint
Re: Step 1, get a pet beaver....
Brian in Brighton
