OT at my wits end
OT at my wits end
OT at my wits end
James Runchey
>I'm extremely frustrated with my printer, A HP 6310 all in one
printer, fax, and copy machine. I have an incoming Email on GMail which will only print the first page, no matter what I do. I put in "print pages 1 thru 3, and all I get is the first page. How do I get this thing to print the whole EMail? P.S, I'm somewhat computer illiterate, so keep it in simple terms that my aged brain can comprehend, Thanks
Re: OT at my wits end
brent
>can you save the message to a file,then print from the file?
brent
John McGaw
>How are you accessing Gmail? If by browser (a horrible method in my personal opinion) have you tried a different browser? If you are accessing it via a real email client, have you tried it with a different one?
Otherwise, it your need is just to get this one message printed out, the suggestion to copy it to a file and then print the file sounds like a good fallback position.
Brent, Brent, Brent He already said....
>he was somewhat computer illiterate. Me too. I have and HP All In One, my second one. Took me days to realize AIO stood for All In One. I like mine and liked it's predecessor, right up to the day it died. But this is a woodworking forum. What kind of file did you want, mill cut, flat, half round? I'd have about as much luck saving it to a Four In Hand Rasp as I would to a file. Mine, like many, sits there telling me it is still low on yellow, until I click on print thing. Actually, until I click on print and then it opens a little screen allowing my to tell it "yes" print on the only printer connected to this computer. Every time. Not very smart. Neither me nor the machine. You'd think after a few thousand times it would learn that there is only one printer, or I would learn how to skip this step.
And, After owning a very similar machine for more than five years I have no idea how to help.
thunderbird
Chuck W
>Have you tried setting up Thunderbird to download messages from Gmail? From Thunderbird you can print any email and you can do a print preview also to make sure that all pages are there to print.
Cut and past to word pad
del schisler
>i belive if you can read the email Can't you high lite it cut and paste it to word pad and print from their That is what i do all the time use the mouse right click and select all than paste to word pad Their is another way you can hold down the left mouse button and drag the arrow down the page to the bottom and tnan do a control C and than bring up the word pad and than control V The control C copy's the text and control V paste it I won't go on Hope this helps The last way is better If you cut it will remove the text from the email So copy with the C and V is the best But you can bring all back with i belive control Z will bring text back good luck
Re: Cut and past to word pad
Curly Smith
>It's easier press Ctrl A (select All) than to highlight a long message. Or, use Edit | Select All from the menu bar. Note that if you have multiple windows open then you should left-click in the window that you want to be the active window first.
del schisler
>lot's of way's to get it done
mamc
>in a word "Lexmark", they work great for me
Hilight and "print selection"
Kneale Brownson..Awaiting return to CO snows
>Most HP drivers have a dialog box where you select parameters of the print job. If you highlight the text ("edit", "select all" or scroll with right key of mouse held down) and then pick the print dialog box option of printing the "selection", it'll print.
Try this
>Highlight just the text you want to print (presumably the sender's name, the date and time, the subjcet, and the text of the message, as well as any inline images) by clicking and dragging your mouse over it. Then hit the print button (or CTRL-P -- the CTRL key and the "P" key simultaneously) to bring up the print dialog. There should be a little round button (called a "radio button") with the word "Selection" next to it. Click that button and hit OK. Your printer should spit out a text document without all the browser/G-mail fru-fru around it.
See if that works for you.
