Have a question? Ask Woody!
Way OT Rotten onion smell????
>My son and I are working on an old house for my cousin. One of the two bathrooms smells like rotten onions. The water has been off for months, so I turned it back on (leaks everywhere as much as anywhere) to fill the traps, thinking it might be sewer gas. Does not seem to have helped. We are keeping the door closed and the window open. The room appears reasonably clean.
Any ideas what it might be?
Re: Way OT Rotten onion smell????
Kneale Brownson..Awaiting return to CO snows
>If there are leaks, could be rotten floorboards under whatever the covering material is.
Did you get all the traps filled?
>While that smell could be many things (you as a house inpsector knows that) I can tell you from personal experience that everytime I've run into that sort of situation, it's been an open toilet trap. Nasty smells.
The only other time I've hear of a "onion" smell was a chemical spill 3 years ago out in the country about 35 miles from here. Turned out to be a chemical/fertilizer plant spill that ended up claiming the life of one of our friends from the church :(
Happy Woodworking!
GalenV in Iowa
>The sink or tub drain could have decaying hair and oil from soaps and shampoo coating the traps and pipe. Filling with water my reduce the smell but you may need to use a little chlorine and then more water to flush the lines. I assume the toilet water has also evaported. Mold can grow on the inside of the rim, bowl and tank. If someone used without water then concetrated urine will often smell like onions.
Is there a shower curtain and is it clean or molded?
The walls can begin to smell if they have been damp and hot if the bath was closed up.
Odors can permeate throughout the room so you may need to wash down everything in the room that may pick up the odor.
Alex Grigoriev
>Another thing you may be aware of that if the copper piping was not drained, and was filled with water for too long, the pipes may start pitting which can cause them to fail in the near future.
Tom Pilsbury (Chicago)
>Might not be the plumbing. Could be coming in through the vents. Or even from outside the window. Maybe a rain gutter. You never know. Follow your nose.
