Have a question? Ask Woody!
Bury my head in shame-finishing ??
Brian in Brighton
>So I made this wonderful black walnut mantle for the house. I am mounting it along side the walnut columns I made 2 years ago and went to find the finish that I put on the columns ( or so I thought ).
Digging thru my cans I found the Watco that I was sure I had used. Wrongo. I put 'dark walnut' Watco onto the pieces and now need to figure out a way to lighten them up a little. I already flooded the parts with Naptha and it took some of the darkness away, but not enough. Any ideas?
I have not used bleach on walnut before and am concerned about how the bleach might effect the wild and amazing grain in the wood by draining it of all it's purtiness.
Brian in Brighton
Re: Bury my head in shame-finishing ??
Lift You Head Up
>Leave the naptha behind.
Take mineral spirits (much slower drying) and a scrub brush, and scrub and wipe with papers towel. You need the bristles to get down into the pores to pull out the pigment that's keeping the wood dark. Rinse again with clean MS and wipe dry with a terrycloth towel. Should come off with little residue.
Re: Lift Your Head Up
Glenn Madsen near San Francisco
>The other part is that some species of walnut lighten with age. Two years could easily have lightened your earlier work enough to mismatch the wood, even if they were from the same log.
Watco also seems to lighten as it cures, in my limited experience with is. Of course, if you used the lighter Watco on the original piece, enjoy your scrubbing experience. I don't think you made firewood, though.
John Pappas
>Brian, I'm sorry that I am not able to provide any suggestions to fix the problem you have. But it seems that your situation provides an appropriate opportunity to suggest, to you and other readers, that keeping a finishing journal is something all woodworkers should do. I started one ten years ago and I have refered to it on many, many occassions to duplicate a finish or repair a damaged finish. A couple of my projects involved a water dye, a pigmented dye and a glaze. I'd remember that for about a month.
Frank in Forest Hill
>Have been there and now I value my "finishing Log".... write it down in a spiral book and call each one a procedure and include the sanding schedule and if you condition the wood before the final sealing. Great for future repairs and recalling "like " applications you my want to do.Just gotta do it.
