OT---Printer question
Gary Evans Tallassee, TN
>Hi all,
We are going to have to buy a new color printer. We don't have a whole lot of cash, but we need it to be as bulletproof as possible.
Any suggestions on what to get?
Thanks,
Gary
>Hi all,
Thanks,
Gary
Re: OT---Printer question
Dave Paine
>So many models, difficult to give specific recommendation. Below are some considerations.
I presume you are looking at colour ink-jets rather than colour lasers.
You do not state whether general colour printing or photo printing. All units will print photo's, but the specific photo printing can have extra colour cartridges. Can give excellant results, but the more cartridges, the more it will cost in replacement inks.
An ink-jet printer can cost more than the purchase price in replacement ink cartridges.
Look for a unit with the individual colour cartridges and a separate black ink cartridge.
Compare cartridge size between models/manufacturers. Generally larger cartridges will have higher initial purchase cost, but can be less expensive when you compare number of pages which can be printed before replacing.
Search on google for whatever model you are considering to get an idea of people's experience.
You do not state the volume you expect to print. Some models will dry out if not used. Most have a cleaning cycle, but this consumes a lot of ink.
These days look at power consumption in standby mode, since unless you power off between uses, the unit will spend a lot of time in standby. Manyunits will do a cleaning cycle after re-starting from power off, another example of ink consumption. So standby power is trade off vs start-up ink consumption.
All the printers should have USB ports. Some will have network, some wireless network.
It is difficult to find information on the printer drivers before you buy, but some offer more functionality for troubleshooting, reviewing ink levels etc.
Epson and Canon designs feed paper from the back vertically and so paper only goes through 90 degree. Less crinkling when printing envelopes.
HP feed paper from bottom and so goes through 360 degree. Can be more compact footprint, depends on model.
Joseph Mulherin, Sr
>Dave has given us all a very good description of what we should search for in selecting a color printer. I personally have the HP 1315 unit for about 4yrs and it does everything you need to have done in printing. Cost was about $130 then.
And, go to the Staples store and get the replacement inks in a package and recharge your own cartridges about 6 times.....except for Dell printers...they will not operate on recharges.
Thomas S Stockton
>I've had great luck with HP printers. You can get a great printer for less than a $100 these days so it won't cost a fortune. The only printer brand I had problems with was Lexmark, bought my kid one and it didn't last very long with very light use.
Tom
Kneale Brownson..Awaiting return to CO snows
>We use HP laser printers. No concern about ink drying out or smearing in a sweaty hand.
If you print large volumes, try to find a refurbisher local to you who can supply something like the LaserJet 4650 line. That's a printer often leased to businesses and schools that sometimes comes off lease with minimal use.
If you're not printing a lot, HP's LaserJet 2600 line is relatively inexpensive new and does just about the same quality.
Only thing we can't do on lasers well is make heat transfer stuff. We use an inkjet printer for that process.
paul in AZ
>Printing machines are cheap and generally pretty good. Look at a test page to see print quality. Some lean towards better text and others to better graphics [photos etc]
Ink can be a killer. It is the consumables that spell the profit to the mfgr. Check out the amount of ink you get per dollar as one rough estimate of eventual ink costs.
I have been happy with Canon. Bad experience with Lexmark.
