attaching deck railing to posts
WarrenC
>how does everyone attach their deck railings to the posts. I'm not crazy about toe nailing/screwing. I'm going to be using cedar for the rails and expect to have problems with splitting etc. I also think the connection is not that strong that if someone were to really lean on the rail, failure is imminent.
Are there brackets available for this kind of thing and if so, where do you get them?
WarrenC
Re: attaching deck railing to posts
>Are you planning to have vertical pickets or horizontal rails? The building Code, which I believe is pretty much the same across the country now (IRC) really frowns on horizontal rails. Too easy to climb up and over. Can't help you with the attachment, other than I used finishing nails that are heavily galvanized.
Rob Lee
>Hi Warren -
We have a new attachment system that will be shown in our July garden catalog... the web treatment should be up very soon...
It's an excellent, strong system...
Search our site for product 01S1800 later this week!
Cheers -
Rob
Re: attaching deck railing to posts *LINK*
Brent Smith in Montreal
>If you can't wait for Rob's stuff, this company makes a great product.
http://www.strongtie.com/index.html?source=topnav
WarrenC
>Strongtie seems to have every type of connector, except for the one I'm after.
Railing
>A sketch of your railing "system" would help. The one I use is quite strong, but may not fit with what you're mounting on your posts.
Rob Stokes in North Vancouver
>I "toe screw".
Mount/plumb your posts (I thru-bolt mine through the ledger board), leave 'em long, make a set of spacer blocks to set your bottom rail (most code has a 4" max gap - I set mine to 3.5"), install the rail by tow-screwing (3" screws minimum), and make another set of spacer blocks for the top rail. Install the top rail the same way allowing the post(s) to be long. Continue until all rails are in. Now trim your posts flush with the top rail and install a 2x6 cap over the whole thing, making sure to scarf your joints and put the 2x6 joints in the middle of the top rail (where applicable). Attach the rail from the bottom up. making sure to "toe-screw" it to each post as well.
BTW - this railing (below) is made of recycled sliding door glass panels. At $20 each - it makes for a very inexpensive railing, and re-uses old building materials. Because you can't cut the glass, the deck has to be sized accordingly.
WarrenC
>I'm still in the design phase for the railing, but am thinking along the lines of this picture I found. Note that I do have some posts that extend all the way up to the roof, so the rail will need to butt into these along with the house
I mortised them into the posts...
John in NM
>I took a pic for you, but my lowest res on the camera is too large to post, and I'm in the middle of stuff so can't restart the computer into linux so I can resize the pic. I can do that tonight if you're interested.
You can also just screw or nail a vertical piece to the post and screw/nail your raitl to the top of that.
That's easy
>Drop 1-1/2" down your post and drill a centered 1" hole through (or almost through) your post. You will then glue 1" dowels in the holes that are the cut/sanded flush with the post. When you mount your railing you'll predrill and then drive your screws down into the cross-dowels. With a railing 4" or more, I'd use 2 stainless screws, #10 or #12. You can countersink and plug them if you wish. If somebody "bumps" that railing, be prepared to treat broken ribs |;-}}}
You can also use sections of 2x2 rather than round dowels for a design alternative if you feel like chopping the square mortises.
Phil Smith
>I am currently in the middle of putting handrail around our porch. The post and handrail are painted salt treated lumber. In my case the hand rail and spindles will need to be repainted at some frequency in the future. I do not like to paint with a brush and spraying in place is messy. My solution was to go to the scrap metal dealer and look for suitable piece of non corrosive metal to make brackets out of. I was looking for a piece of stainless angle about 3" X 3". What I found was a piece of 3" X 4" heavy aluminum angle. I have cut pieces 1.5 inches wide and mortised those into the face of the post and into the bottom of the handrail. The brackets are held in place with Stainless screws. With the brackets mortised into both the post and handrail most of the load is carried by the wood shoulders of the mortise and not by the screws. By unscrewing the hand rail I can remove each section for repainting as needed.
WarrenC
>thanks for all the input
WarrenC
Re: I mortised them into the posts...
Fred Davis
>As do I , it is far stronger to mortise the bottom rail into a 3/4" dado then any toenail systems and much more attractive
Draw two lines representing the thickness of your rail stock and cut inside of them several times with a skilsaw and munch out the material with a few taps of a chisel.
If the mortise stays tight , that is all the fastnening you will need.
For the top rail , run it on top of the posts and mitre the corners.
Pickets or balusters look better if they are centered on the middle of the of the rails ,rather then nailed to the outside or inside of the rails edges.
Running a 1 " square strip , off set the amount to allow the pickets to center against it and act as a backstop will allow you easy spacing and fastening to it.
FredD
