Fret work layout question
Bill Tindall, E.TN
>How does one lay out fret work and get the repetitive line spacing perfect such as in this tray? And then there is sawing it perfect...........
Re: Fret work layout question
>I suspect that it was laid out and cut by machine.
Clint
Joseph Mulherin, Sr
>Bill, I do not know what others say about doing layout work like this, but this is what I would try to do....
get some posterboard and draw out the lines in pencil, make corrections by erasures and redrawing, then cut it out in sections, lay it on your workpiece and draw your lines to cut on.
Use a spiral coping saw in your motorized coping saw; drill a small hole in each part to be cut out to insert the spiral saw thru.
Repetition of the pattern can be set from a small drawing section setup. Hope this helps......Joe
Here's what I would do
Neal in San Jose
>I'd let the fretwork drive the other dimensions.
Roughly lay out the tray or table top to the size you think you'd like. Say the fretwork works out to be 37 1/4 inches long on your first pass. You could use that dimension, but it would be tedious. Adjust your rough lay out so that the fretwork is the driving dimension, say 36 inches. You could then easily have a one inch (or any other dimension that divides into 36 evenly) pattern repeat. Then just adjust the other dimensions to fit the fretwork. You'd probably only have to adjust one or two other dimentions, like overall length and width of the top, but that should be pretty easy. You could do this "backwards" and start with the fretwork pattern size, repeat it until you get close to your rough fretwork dimension and adjust the other dimensions to fit.
You could also leave a short section on the fretwork uncut on each end. It would look like it is supposed to be that way, and as long as it was equal on both ends, it would look right. I've seen it done that way and figured that's what the maker was really up to.
You could also have the fretwork die into another feature like a handle or back piece. A mortise would then swallow any partial patterns. As long as both ends were the same, who would notice? I've seen it done this way with metal pre-punched fretwork where it would be almost impossible to do any other way.
David G. Sparks
>If the piece is flat you can lay it on a photocopier and make a copy. Or you can use clear plastic film like mylar and a fine point Sharpie to trace a pattern by laying the film over the piece. I've also traced cutouts with a .5 mm mechanical pencil onto paper, but I see part of this piece has wood behind some of the holes. I work almost exclusively from ready-made patterns. You can probably find a pattern from one of the vendors such as Wildwood Design, The Wooden Teddy Bear, or Scroller that would be similar. Patrick Spielman published a book called Borders, Trim, and Frames that has this kind of pattern in it.
I know it was not in the 18th century
Bill Tindall, E.TN
Graph paper
LGuthrie - Merrill, Wi
Lee Grindinger
How about some numbers?
Lee Grindinger
>Bill, would you measure the width of each block and the width of the frame..., I suspect it's an easy layout.
JanManuel
>Draw your pattern in your computer...get the spacing exactly as you need it. Print it on full sheet sticky label paper...this works even if you've either steam bent the wood or made a curved lamination.
Nice thing about using the computer..is you can fine tune the size when you print it....
BrianA
>Print it out on regular paper, Put a layer of packing tape on the wood, use a spray adhesive and glue the paper onto the packing tape. Drill holes in the "waste" portion and use your scroll saw to cut it out. The packing tape helps to lubricate the blade.
You ca get a lot of info from a good group of scroll sawers at http://www.scrollsawer.com/forum/
Brian
