Oversized Drawer Construction Q
Bill H - Evansville, IN
>I'm building some wide drawers (36" wide x 22" deep) intended to hold pots and dishes in a kitchen cabinet. I made the sides 3/4" thick to add extra strength. My question is how to construct the bottom. Is it better to use 1/2" (or even 3/4") plywood or 1/4" plywood w/ 3/4" poplar support pieces underneath? It seems like strength wouldn't be a problem for any thickness, I would think sagging would be the issue. Would 1/2" be strong enough not to sag w/o support? Any thoughts?
Thanks in advance,
Bill
Re: Oversized Drawer Construction Q
>I have some drawers in my shop cabinets which hold numerous planes or numerous hammers. I used 1/2" bottoms. The drawers are ~20 x ~20 x ~5". They have held up reasonably well. I have also used 1/4" plywood with dovetailed wooden guides across the bottom. These also have supported well.
I don't really think it will be a problem with either 1/2" or a supported 1/4". IMO, the 1/2" does "sound" more solid and I feel more secure with 1/2" bottoms.
Sort of indirect info....
>In constructing a roof, you can use 3/8" or 1/2" plywood for trusses 2' OC. (It has to be rated for the application and has to have the edges blocked or supported, but it can be used.) From experience I know that walking around on the thinner stuff feels a little like walking on a tent or trampoline. Just a little springy. The half inch (actually 7/16") stuff feels much more solid.
So, I am sure that the thinner stuff would be fine but might sound like a drum. I think my bigger drawers in the shop have 3/8" bottoms, but they might be 1/4". I think some supports under it might be a good idea. I would suggest something nice and stiff, like oak. The only way you would know if they were really necessary is if you build them without supports and one of them fails. Although probably not necessary, I think you would feel better about the half inch and thus it would be better.
Lee Grindinger
A thicker bottom is better
Lee Grindinger
>Use the 1/2" bottom and glue it in all the way around. The thicker bottom glued fully will make for a more rigid drawer that will help resist racking. The thicker bottom will make it feel much more solid in use. I used 1/2" Baltic Birch routinely in all but the smallest of drawers.
The assembly technique I used was to cut a 1/4" groove in the sides, then rabbet the bottom so the the bottom consumed only 1/2" total depth of the drawer.
Lee
Drawers not typical solution to problem
Bill Tindall, E.TN
>More common today is to put pull-out trays behind double doors on the bottom cabinet units. The trays have 3/4" bottoms, short sides and full extension slides. Personally, I think this arrangement looks better than chest sized drawers in a kitchen.
Captured on 4 sides in a dado any sort of plywood bottom will be strong enough, but as others have suggested, 1/2" will sound more robust whilst dropping cast iron fry pans in it.
Lee....Great idea....
Terry Alexander
>I have made many posts in the last 9 months as I am building my own house....cabinets, vanities, installing tile....etc.
I intended to use 1/2" material for all my drawer bottoms. My reason is that I do a lot of cooking and I have a lot of pots and pans. In my previous house, I had to replace the 1/4" material with 1/2" material in several drawers because of sagging. Your idea regarding rabetting a 1/4" on the 1/2" goods and then a 1/4" dado on the sides is terrific. Just in time as I will begin construction on the cabinets in < 30 days (still have to finish the tile first).
Thanks for the post and "tip".
Terry Alexander in West Texas
Lee Grindinger
You are entirely welcome...,
Lee Grindinger
>And, just for future reference..., in North American terms a groove runs with the grain, a dado across the grain. A groove is often cut with a dado blade but the end result is still a groove as long as it runs with the grain.
Enjoy the work and keep asking questions,
Lee
John Cotten
>I forgot to mention that I dado my 1/4" drawer bottoms in 3/8" into the 3/4" drawer material 3/8" up from the bottom of the drawer. I will be building 13 drawers tomorrow morning and will take a camera to get some pics during construction.
I have included a second pic of the drawers in the loft kitchen I did last year.
Thanks for all the great info!
>Thanks for the great insight. I think I'll go w/ 1/2" plywood.
Thanks,
Bill
AZ, Colorado Springs
>If you were building a bookcase, would you use plywood across a 36" span with no additional support? Books are heavy, but in a drawer 22" deep and 22" from front to back -- you can put a lot of stuff in there and load up the drawer bottom with a lot of weight.
So, the next question would be: do the front and sides of the drawer provide sufficient support, as if the plywood was edge banded? I don't know. The others who have provided comments have more experience with this. But I think I'd include a support underneath the bottom.
