Converted my Performax 16/32.....
>To an open drum sander. I have made a prototype table that sits over the drum on my Performax. I see this as allowing me to sand things too large to pass under the drum. I think it only opens to 3" thick, so now I and sand much larger objects. Might even be able to use it somewhat like a jointer to level up things like boxes.
Whats left is to connect the dust collection. I need an elbow to allow for the connection of the hose. I think the Borgs are closed for the forth, but I will get one tomorrow.
Re: Converted my Performax 16/32.....
Very innovative!!
Marv
Nelson
>Great idea, now I don't have to buy a Sandflee.
>That was my thought. I saw a Sand Flee after I already owned the Performax. I have used the Performax with the top open, but you don't have a table. So far, this is better than I thought it might be. It has some little brackets (?) under it and it just sits in place. Literally open the top and sit it in place. Connecting the DC is going to be the most complicated part. Whole thing is built out of a 2' X 2' piece of 1/2" plywood.
Nelson
>If you raise the drum up the 3in and istall a box a little more than witdth of housing and add a dust port on it do you think it would collect the dust? Just a thought.
>I'm going to try just using the existing dust port. The drum spins toward the lid. I have only played with it for a few minutes, but I am on my way in a few minutes to get an elbow and see if that works.
If that does not work well, I will try your idea of a box under it.
Great idea! Thank you!
David G. Sparks
Had a complete brain F@rt trying to connect the
>DC. Made and adapter to fit under the hood. Kept whittling it down and down and made another piece to fit on it. Once I got it working had one of those head slapping DOH! moments. Could have just raised the drum about an inch and saved a lot of work. Duh. Of all the things I've had and lost, I miss my mind the most.
Works great.
