Dremel repair
Jerry Gibbs
>Smoke came out of my A/C Dremel and then it quit. Should I even bother to try to fix it? I don't have much experience with motors. Jerry Gibbs
Dremel repair
Jerry Gibbs
Re: Dremel repair
>Good Afternoon Jerry,
I'd call Dremel first to determine warranty applicability and/or re-build cost and prog that info against the cost of a new item. My Dremel is a thousand years old. I bought it new as a young man.
George
Re: Dremel repair
Jerry Gibbs
>and as I have learned from ebay, always factor in shipping. Jerry
Many, many . . .
steve mackay
>I go through the hand-helds like Klenex. While I've sent my Hang'n Monster Dremel to the factory three or four times I pitch the hand-helds when they smoke or slow down. Not worth it. I DID find a money saver though. Find (Iknow its hard) a good pawn shop. My fav is Cash America here in El Paso. A good shop tests stuff when they take it in and won't touch worn-out-looking stuff. Twenty bucks usually. I can get my twenty bucks worth out of them in a week.
Re: Dremel repair *LINK*
Kneale Brownson..Awaiting return to CO snows
>When mine smoked, second use after having had it for a year or more, I sent it in and got a new one sent to me for way less than half the original cost. Their website includes a list of repair costs if they don't give you a replacement. If your tool is obsolete, they'll replace it for the maximum repair charge, which is about $25.
Dremel Repair Chart
Re: Dremel repair
Jerry Gibbs
>Thanks Kneals- Jerry Gibbs
Re: Dremel repair
John_in_Az
>My old but lightly used Dremel bit the dust recently. It got too hot to hold in about 15 sec of use and lost power and rpm. I was kinda shocked about the generally poor ratings given to Dremel these days. Seems more than normal failures reported.
For a few dollars more I bought a Proxxon. It's far smoother than the Dremel with brushless permanent magnet motor. The model I got has a small chuck to take various dia shanks up to 1/8". I'm hoping it will handle more continuous use better than a Dremel. John
