Manual, little Delta sander
>I just picked up a Delta 1x42" sander with 5" disk, Model 31-080. No manual, of course. Anyone happen to have the manual for this?
Re: Manual, little Delta sander
ben d.
>Check the Delta web site. There is a manual site that you can print some manuals directly from there. I printed an older scroll saw manual about a year ago and would suspect it is still available.
You may also check on old wood working machines depending how old it is.
http://www.owwm.org/viewforum.php?f=1
Hope this helps you out.
ben d.
Howard Norman
>I have the sander but haven't any idea what happened to the manual. As someone else suggested go to the Delta site. It is probable available there.
Kneale Brownson..Awaiting return to CO snows
>I have their 1" belt/8" disk, but nowhere on the machine or in the manual does it have a model number I can find. Could yours be that model? I can supply a copy of the manual for that one.
Alas, no joy with Delta
>now that they're owned by a conglomerate that's using "service.net" (or, as I've been thinking of it, "useless.net"), the quality and availability of that kind of thing is way down.
