Anyone use a rechargeable aerosol can? *LINK*
>Okay, I've been on this Internet forum for 12 years (sorry, a bit less since I started on Badger Pond) have been woodworking for 37 years (started at 5 in Boy Scouts, Beavers actually) have been buying tools for almost 30 years, have had a 60 gallon compressor for almost a decade..... and this is the first time I've ever heard or seen of this?!?!?!
This is just too cool...... and ANOTHER perfectly valid reason to own a large compressor :)
I've gotta get one of these to try.
Happy Woodworking!
http://store.wagaero.com/product_info.php?products
Re: Anyone use a rechargeable aerosol can? *LINK*
Oh, and here too *LINK*
>Harbor Fright of all places ;)
Happy Woodworking!
http://www.harborfreight.com/cpi/ctaf/displayitem.
Ken Oakley-Sunny St. Cloud, Fla.
>I have had one for 12-13 years. Not as pretty but works great. I use mine for oil only. When it empties, unscrew cap, pour in oil, fill it with air like you would a tire and you are ready. No aerosol cans to go to landfill.
Ralph Lipeles
>I would expect that with the small volume of relatively low pressure air that it would be difficult to do a good job spraying with it.
Not
>Giving up my CAT HVLP minigun just yet, but I can see uses for this , especially in the kitchen.
R. Gryder
>I used one of these when I was a teen working at a service station to spray cleaner on windshields. Worked great. And it has been a darn long time since I was a teenager. Gosh, a long time. R.
Howard Norman
>Those things have been around for a long time Mark. Never had one so can't comment on how they work but I can recall hearing/seeing them a long time ago.
Alan in Little Washington (NC)
>Only problem, unlike rattle can sprays which use other gases, you are using air as the propellant which will cause a finish to skim over, dry, harden, etc. if you leave it in the can. Plus, I guess you need to drop in a marble so it rattles.
Bill Hammond, Oregon Coast
>We used them a lot in prop shops. Great for spraying dye and stains. Also worked for shellac but you had to clean it out or the spray tip would clog up on you. If I remember correctly we used different tips, a wide fan spray and a small cone.
I could see using it in the kitchen for olive oil, but I expect that SWMBO would see otherwise.
Bill
