A55 Smoothing Plane
Outdoor finish - before picture------WebKitFormBou
Eric in Silicon Valley------WebKitFormBoundaryNeuJ
>I finished some Honduras Mahogany outdoor furniture, but I'm not very happy with the results. I used Cabot's Australian Timber Oil after several recommendations, but the finished look is not near as nice as the raw material. The before picture is freshly sanded, the after picture was finished about a month ago. We have had no rain, and our humidity is fairly low.
If I'm doing something wrong in the prep, or using the wrong material, or anything else I've possibly overlooked, I'd love to hear from you.
Thanks in advance,
Eric
------WebKitFormBoundary+L9xENClTdkwca4k
Re: Outdoor finish - before picture------WebKitFormBou
Re: Outdoor finish - after picture
Re: Outdoor finish
Al Stokka - Cambridge, Iowa
>Eric,
I think what you're seeing is the effect of ultraviolet radiation from the sun. Does your Austrailian Oil contain a UV blocker?
Al
jerry mayfield
>It looks a lot like an oil varnish blend. Linseed oil,alkd resin,a little tung oil and a little color. It will never be a gloss finish and will need maintenance on a regular basis.
Jerry
>I couldn't find anything about UV protection on the can. It says to use one coat, every 1-2 years. Designed for outdoor use. I'm not concerned about a gloss finish, i just liked the look of the wood before the finish, and IMHO, it looks better without the finish than with.
The UV issue might be it, the legs, which see less sun, look much better than the top.
