Outdoor Furniture????
Andy Lincoln,in Dearborn,MI
>Hi All,
One of the ideas floating around in my head is to build some outdoor patio furniture.I'm actually thinking something similar to a Morris Chair and a Sofa/Loveseat to match instead of the "typical" adirondack style chair.
My reasons among others are ,I've never built a Morris Chair and would like to"practice" before building with QSWO for interior use.
What type of wood would you consider to build from?Cedar,Ipe,Teak,Cypress,Ash,Elm,etc? I plan to have cushions made of outdoor fabric if not just simply to buy them at the home center.
Here in Michigan the weather can be harsh,especially the winter.We are in the habit of storing our current cushions in a deck box when not in use,keeping them dry and non-fading from the sunlight.The same care would be used on the new cushions as well.
But,the chairs/sofa would remain outside exposed to the elements as any indoor space they would require for storage means I lose even more shop space,and we all know that the shop is too small to begin with.I could also look into getting weatherproof covers for the furniture as an added measure of protection.
I also am not objecting to applying a finish such as Cabot's Australian Oil as it is what I use on the cedar on both my hot tub and my outdoor kitchen(which is another work in progress.)
I'd love to hear some thoughts on the subject.
TIA,
Andy
Re: Outdoor Furniture????
Dave Bair, Eaton Rapids, MI
>Actually, white oak is a good outdoor wood. While it is quite heavy, it'll keep the furniture on the deck during our thunderstorms instead of tumbling across the backyard. And it will also let you work with white oak in prep for your indoor stuff... not that you need any additional experience. Adirondack furniture is pretty low-slung for my older-model frame so I think a Morris-style would be an excellent choice. But quarter-sawn might be a little over the top for the deck.
Jesper, Denmark
Jesper, Denmark
>If you can find some, then Black Locust is perfect for outdoors. No need for any finish.
Scrub with water and a stiff brush in spring and you are set for the summer.
mdclor
>Jesper,
I thought of black locust, but have never seen it in a lumber store. The other thing is that it is so hard that I am not sure that it can be machined even with a 5 hp cabinet saw. LOL! On the flip side, it is great for fence posts (if you can find straight sections) and will last for 40+ years in the ground.
Merle
Chet Kloss
From a fellow Michigander
Chet Kloss
>Wood: Cypress
Sealer: CPES Clear Penetrating Epoxy
Finish: Epifanes Gloss Clear Varnish
Dave Paine
>I made this chair initially as outdoor furniture. The shape and angles were a combination of two separate plastic chairs, one Adirondack style, slung low to the ground, the other a normal porch chair.
I liked the seating position of the porch chair, especially if I pulled a back muscle. I liked the wide facing front of the Adirondack style.
The back is curved for lumber support, which is why the slats are horizontal. Personally found this to be the most comfortable for my use.
Originally made two from Cypress. Within 1 year lots of cracking. I am in Eastern PA, so not as much snow as you, but still hot in summer and cold in winter.
This picture is the second set, made from a mahogany species, not sure which one since the place where I got the wood did not know. These were coated in external urethane.
After 1 year outside, I decided to bring them inside.
If I were to build new ones, I would consider white oak, after all, how many oak barrels have you seen exposed to the elements. Normally look weathered, but hold up.
For outdoor finish, I like Sikkens Cetol exterior finish. Expensive, but holds up to the elements. I made a side light for the front door from different mahogany. Been in place for 3 years, looks like new. Does not get much sun, but does get a lot of rain and snow thrown at it.
