Phone first!
Phone first!
Phone first!
Tom Pilsbury (Chicago)
>Remember the old Yellow Pages advertisement that encourages you to "phone first" to avoid complications? Well, I'd like to trumpet that message here and hope it benefits my fellow woodworkers.
The other day I unwrapped my new Freud Premier Fusion 10" P410 saw blade. I noticed that there was a glue like substance that filled the squiggely cuts in the face of the blade. I know those cuts are there for a reason so I thought I should remove that material to improve the air flow. However.... it sure looked like that stuff was put there intentionally. Hmmmm...Maybe I should call Freud and ask before I do anything. Wheeew! Sure glad I called! The customer service rep said "No, No, No! Do not remove that stuff because it will compromise the integrety of the blade." I installed the blade as is and it cuts just fine*. Moral of story: Phone first!
*It cuts fine but don't use it for grooves. You'll get a serious V.
Re: Phone first!
Re: Just wondering
Larry Clinton At Frankfort (Central)., Indiana
>I know the slots are cut to reduce "warping" of the blade as it heats up during use. I always thought the "filler" used in the slots on some blades was used to reduce noise - whistle etc. as air passes over the slots. As an Engineer, I really can't understand how removal of any filler could "compromise the integrity" of a blade. I could see it affecting the balance if just part of the filler was removed, and/or making the blade noisier. I just can't see any "filler" material having the strength or adhesion to really have any major effect on the strength of the blade. If the filler is necessary to maintain the integrity of a blade, I wouldn't use that blade.
Re: Phone first!
Re: Just wondering
>I was just paraphrasing his comments. He did mention whistle though.
Re: Phone first!
Re: Phone first!
DizD
>Had a similar situation except the plastic blade wrap had fused with the filler. I ran it anyway figuring the cutting action would clean it off and wound up with melted plastic smeared around the blade. I called the service rep and he sent me a replacement blade. Good blade, good service. I'm happy with performance to date.
