OT again, Insulation strip for Patio door
>I just realized that the little fuzzy insulation weather strips in my ancient aluminum patio door have apparently reached the age where their hair fell out. In the last month or two, most of the fuzz has just gone away. Any idea where I can buy replacements. These are about a 1/4' wide and slide into a groove.
Re: OT again, Insulation strip for Patio door
Re: OT again, Insulation strip for Patio door *LINK*
Mark Nowicki
>If you can tell me which one you need I can get for you and mail it.
Another option would be a local window repair shop.
Mark
Schlegel pile weather seal
Jim DeLaney, Austintown, Ohio
>I got mine at a local glass/window repair shop. Cheap, too - maybe 25� a foot (about five years ago).
Jim D.
And Another question?
>How do I install this? I realize it slides in from the end, but do I have to take the frame apart to do that? That means I would have to remove the frame form the opening, disassemble it, install the strips and then assemble the frame and reinstall it. Can you do it without all that? I thinking about cutting away part of the "track" or groove near the top?
Re: And Another question?
George Koch
>Barry, In my opinion you shouldn't cut a portion of the channel out or you will have trouble keeping that part of the new weatherstrip in place. Remove the sliding unit and then the fixed unit from the jamb. You might have to remove a sillcap piece and a top stop to slide the fixed panel out of the side jamb before you pick it up and out.
The old weather strip should slide out from the top or bottom and the new one slides right in if its the correct size. The just reinstall the sashes in the reverse order. Hope this helps, George
