Start With Wrong Assumption
>Condensation in an A/C unit's refrigeration coil (the one in the furnace plenum) is the consequence of passing warm/moist air over the cold coil. Almost ALL of an A/C's energy is used to run the compressor and evaporator fan which sit in the "hot" coil outside. The balance of energy used is for the air handler (furnace fan) and the small condensate pump). The guy is pushing hokum. The A/C compressor, based on Boyle's law, removes heat from the internal air stream and the pumps it outside tothe heat exchanger. That it also operates as a dehumidifier is incidental to its function of chilling the warm/moist air stream.
A dehumidifier, being a "spot" unit, uses the same principal, but returns the warm air to the same space; needing another fan to circulate the drier air in that same space to bring moist air back to the unit. To get the same amount of reduced humidity in an entire structure, you'd need a dehumidifier and fan in most of the rooms. Then you can spend your time running around emptying the #@$!! buckets. I have two 60-pint dehumidifiers running in my basement office/shop area from April through October. While they dry the air, removing 16-20 gallons of water each day, they also warm the space beyond what I'd call the comfort zone. More simple physics here, the heat generated in the units' exhaust coils together with that from the compressors and running motors is more than the chilling effect of the condensing coils.
We also have and use central air.
