Agree with Mark
Bill Howatt
>They are designed for simplicity (cheap to make) and do not have exotic control systems to maintain the power at a prescribed level. The magnetron/transformer is designed to give a certain power when it is in the early stages of its life and anything that changes is not compensated for.
All of the fancy electronics is safety-interlock and timer. The power-level is not done by a fancy control system but by varying the duty-cycle within a time-frame. You can usually hear the fan speed rise and fall as the line voltage at the fan changes slightly when the magnetron turns on and off if the power level setting is reduced from full-power. You may also hear a clunk sound from the transformer as well.
Most likely the electron emission from the magnetron's cathode has dropped off resulting in less power. This was a common happening in radio/TV vacuum tubes and the magnetron is just a different type of electron tube.
Bill
