mortising
jan derr
>what is the best way to mortise and tennon a leg to apron joint. I am building a shaker style dining table want it to be traditional piece.
thanks
mortising
jan derr
thanks
Re: mortising
Fred Davis
>If your doing it by hand , rather then with a Mortiser, layout the Tenon , , drill out the waste and clean up with a chisel.
Since the leg is generally much thicker then the Apron stock, center the Mortise and remember that if you cut the Tenon to reach the center of the leg , then it will need to have a mitre cut on the end to mate with the Tenon coming in from the end Apron, rather then just running into each other whick will cheat one or other in length
FredD
Not sure what your question is......
>Are you asking how to cut the mortise an tenon, as in what tools to use, whether to do it by hand or to use machines, etc? Or, do you want to know the design and dimensions of the parts as in how thick and wide to make the tenon, whether to center it on the apron, whether to cut the mortises so that they intersect and require mitering the ends of the tenons, Etc?
I made a table a while back and got some advice here. One of the things that I think I learned from the process is that the joint works differently than I thought. Not only does the strength come from the glue contact area, but also from the fact that there is a shoulder on the end of the apron. The shoulder provides a fulcrum and gives the joint strength because any flexing of the leg makes the shoulder act as a fulcrum and try to extract the tenon from the joint. This puts the glue into shear and it works well that way. Thus, a tenon that leaves a shoulder on the apron would be stronger than just inserting the entire apron into the tenon. Not sure I have explained this well, but it was an Aha! moment for me. You are trying to find the combination that leaves a large strong tenon but does not have a mortise that cuts away the strength of the leg.
