Re: It's bad news if it is contact adhesive
Keith Newton------WebKitFormBoundaryV6MZb+tiOpocz6
>I did some loose veneer repair on the ends of some church pews that was laid up with some kind of glue that seemed to have suffered from a short working life also.
It sounds like your description was like this stuff was.
What I did, was to slip a piece of sandpaper in between the substrate and loose veneer. I would then press on the front while pulling the paper out. This brittle glue turned to powder easily. I then blew out the dust, then worked the medium viscosity Cyanoacrylate into the space with a scrap piece of veneer.
I had a block of 3/4" mdf which I had covered with the thin packing tape to use as a platen. I held the veneer out and gave it a quick shot of activator, then quickly pressed it down with the platen. The glue is cured in less than a minute, and has pretty good bridging strength.
Have a rag handy to soak up any run-out, but be careful and wear gloves, because it gets hot enough to smoke when it cures.
If there is a good finish on the face, it can be chipped off with a blade.
