Alrighty Then another deck ? Fred Davis anybody
Dustmaker Mike
>So here goes. Fred Davis said he used the out door PL500 I think. So this got me to thinking (I know dangerous). Can I use it on PT 2X4 and just run a toe nail in the side of it until it dried? I have a framing nailer and wanted to use the cheap 2.5" nails to hold it until the glue dried. Will that work or will I need the nails for PT lumber? The longest run in this section will be 7'. The next run will be using 10' long boards max.
Thanks now I know why I took an inside desk job I hurt(-:
Re: Alrighty Then another deck ? Fred Davis anybody
Fred Davis
>Mike,
The PL500 will work fine on any wood wet or dry or frozen even.
When using thee nail gun to toenail the leading edge of the board , be sure to stand on the board to keep it flat, because it is easy to roll it up if your not paying attention.
You should be good to go and I bet you will like the unblemished by fastners look of the deck.
FredD
Check Locally
>On that glue and toenail option. I've seen several decks in my area where the attempt led to accelerated decay from poor drainage and loose boards that had to be screwed down later. Calling a quality lumber yard and/or several well respected deck builders in your area may get you more specifics on do's and don'ts based on actual experience.
PS
>Personally, I rather like a nice straight line of screws in exterior decking. I lay mine out with mason's line centered on the joists, and take care to set them to the same depth. I think it shows craft and attention to detail. YMMV
