Deck Post Sleeve Cap
Joe E
>I recently made some Deck Post Sleeves and of course they aren't standard size (about 6 1/4 square) and I am having difficulty in getting caps at a resonable cost.. Honestly I look for the excuse to make them myself. I would basically cut a square about 7 1/4 square and bevel the 4 sides at about 15 degrees.
The problem I am having is with the bevel. I was thinking about ripping a 2 x10(7 1/4) to the width I need then cut the bevel on upper and lower , then cut to width, then use a jig to make the remaining 2 cuts on each individual cap. Then add some molding to the bottom or route the bottom instead.
It appears my 10in table saw can't give me enough height to cut the bevel.
Does anyone have any ideas, maybe another way to approach making these or a place I can buy the the beveled cap blanks???
Thanks for your thoughts.
Re: Deck Post Sleeve Cap
How many are you making?
>If I understand your project correctly, a jack plane should do the job. For a relatively small quantity of caps, say under ten, it might even do the work faster than you could set up a jig to do the work.
You could also do a hybrid: cut as much as you could on the table saw, finish with the plane.
Re: How many are you making?
Joe E
>Bill - I hope to make 11
>Then, yes, rough cutting what you can with the table saw and finishing up with a plane should be very feasible.
Of course, you could always buy an 18" bandsaw instead....
>I'd start them on a TS and finish them on a Bandsaw. Then tough them up with a ROS. Might just set up a jig and do them on the BS. I have a 14" BS with a riser.
George Koch
>Joe, have you considered making them up in four triangled pieces and glueing them up with titebond III. I've found this simplifies the operation, eliminates the exposed end grain, and therefore cuts down on the cupping and splitting that these caps are proned to. You can rip your beveled stock from from both sides on the table saw, then cut all the miters on the chop saw. I've never had any callbacks doing it this way. George
I made several
Bricofleur
>Joe,
I made several of them few years ago for a friend, but they were not as large as yours, maybe approx 6" X 6".
I ripped and crosscut a 2 X to get the appropriate number of square blocks and I beveled them, safely, using my tenoning jig (times 4 for each cap). I thought I could do it free hand but when I was ready to try it, it was too scary to have my fingers so close to the saw blade.
Since I have a commercial (Delta) tenoning jig I was able to tilt it at the appropriate degree (can't remember the exact figure here).
Since your squares are that large you won't be able to get a sharp tip on your caps using this method. Part of the top will be flat.
I would use the same method again.
By the way, I remember she stacked two of them on each post to get "lantern" style caps.
Best,
Serge
www.atelierdubricoleur.spaces.live.com
Re: I made several
Joe E
>Thank you everyone. Great ideas!
