SawStop...OUCH!!!! *LINK*
Joe Pack
>Now THIS is putting your money where your mouth is! (The "OUCH" was because it STILL makes my blood run cold!)
http://finehomebuilding.taunton.com/item/8228/sawstop-inventor-walks-the-walk
Joe Pack
Re: SawStop...OUCH!!!!
>I've seen this before and ouch! I would not have that much nerve. Gives me the willies too.
OTOH, you notice he did not sling his finger into the blade the way they do those hot dogs. He sneaked up on it pretty slowly. Don't blame him but he had a chance to pull it out of the line of fire if it did not stop. And, I still ain't doing it.
R. Gryder
>You have to wonder how a piece of damp pressure treated wood would do. If the device sensed the moisture and salts in the workpeice there would be problems.
By the way. I am with Barry. I aint trying it.
>Even though I ain't trying it, I am in favor of the Sawstop. If I had the money, I would buy one. But, you raise a good point. My understanding is that if you are cutting green wood or wet treated wood, you must turn the Sawstop feature off. I'm sure I would forget or would forget to turn the feature back on. That is not a reason to not buy one. If you don't buy one because you might forget, you need to understand that the saw you have now is NEVER going protect you the way this one might. And I still ain't trying it. I have cut myself on a TS. The price of a blade and that shoe thing is really really cheap. CHEAP.
Correct on all counts!
Bill Howatt
Well...If that's the case, you have bigger issues
Hikmet C. Sakman -- Victoria, BC.,CDN
>...and that is cutting wet or pressure treated lumber on a cabinet saw. I don't think so! But that's just me.
Chico...
Re: It won't let you forget. . .
Dave Mount
>Barry, the SawStop override self cancels as soon as you turn the saw off. Next time you flip it on, you're back to normal operating mode, unless you re-initiate the override.
I'm with Chico on cutting wet green treated lumber on a $3K cabinet saw. However if you choose to, you can test a piece of wood with the saw off. Touch the wood to the blade and the light display will tell you if the wood is conductive enought that it would set the brake off it were on. This might not speak to a piece of wood that's surficially dry but soaking wet in the middle, I don't know.
I set by brake off by hitting a hidden nail. Some would complain about this, I saw it as mildly reassuring that my saw was properly configured to go off when it hits something conductive. The fault was mine, not the saw's.
At the price, a SawStop is not for everyone. But it is a very nice saw, and I don't regret for a minute having made the investment.
No connections other than being a happy customer.
Dave
Even Cheaper
David Yoho
>It's my understanding that Saw Stop will send out a new break mechanism at no charge if they determine it was skin contact that set the device off. I've been told they have an accurate method of testing the fired "shoe" for skin contact but have no idea how they do it.
David
Re: Even Cheaper
jan derr
>work safely no matter the tool
