6" S&D pipe in Southern California
doug f, san clemente, ca
>Anyone know where you can purchase 6" S&D in So. Cal. I'm redoing my dust collection system (finally!) and I can't seem to find any except back east.
Thanks for the help.
Doug
Doug
Re: 6" S&D pipe in Southern California *LINK*
John McGaw
>Some quick research suggests that these folks can provide what you want although they may not have it in stock and may need to order it in for you. Probably worth a phone call though...
Possible Pipe Purveyor
mdclor
>Google "pipe 90210" but replace 90210 with your actual zip code.
HTH,
Merle
Try Lowe's, if you've got them.
Dave Bair, Eaton Rapids, MI
Thanks
>Thanks for the leads guys. Horizon looks promising and the Google search turned up about 12,000 sites. I'll work on that one.
I've tried the local Lowes; mostly I got blank looks and suggestions about using cast iron for a sewer line. Oh, well...
Thanks again.
Doug
Re: Thanks
>Interesting. Here in VA both Lowes and Home Depot had the pipe. HD had only and very limited selection of fittings. Lowes was much better.
When you find it, look inside. I found some of it to be very rough. Rough enough to possible cause clogs. Pick the ones that smooth and slick on the inside.
Alan in Little Washington (NC)
>John Deere Landscapes, a nationwide chain of vendors of landscaping supplies for professional landscapers, carries 6" S&D. They have 43 locations in CA (see link).
As a non-landscaper they will charge you almost double what they charge a professional landscaper so find a friendly landscaper to buy it for you.
