We value your privacy.
>If I reduce the Decibels from 65 to 50 what per cent will I reduce the noise level? A muffler I am looking at is supposed to reduce the noise level by 50% and the same ad says it will reduce the Decibels by 5 to 15. How can this be? Is it true?
>a increase of one Decibel is a ten fold increase. From 1 to 2 Decibel is a power of 10 increase. This scale is suppost to follow the way we hear sounds. So yes the sound could be reduce with a less than 50% reduction in Decibels. I am sure others will post with a better explanation than I have.
>Decibels are on a logarithmic scale, so the percentage reduction really depends on your starting level. Basically, 10dB starting at 90dB is alot more total noise than 10dB starting at 40dB.
I don't have a DC, so I'm just guessing here. I would think with a cyclone you might be able to enclose it in a sound dampened box. You would put a box around the cone, but not rigidly attached (as a rigid attachment would transfer the vibration to the box). You would want to keep the motor exposed, so it gets sufficient air cooling. I don't know what I would try for a normal DC (since the fan directs everything into the bag/canister).
>The decibel scale is based on the logarithm of the ratio of two power levels. Each increase of 3 decibels is an increase of 2 times in power. Similarly, a decrease of 3 dB is a decrease to one half in power. So in engineering use the dB scale is a relative one.
In terms of audible noise the dB noise power output of a machine is referenced to the minimum sensitivity of the human ear (the ratio of the machine output noise power to the minimum power you can hear). So the stated machine noise level in dB is an absolute measure of noise power.
A difference of 3 dB between two machines means that the machine with the higher dB level puts out twice the noise power of the other machine. And a difference of 12 dB would be a difference in noise output power of 16 times (12 dB = 4 x 3 dB = 2 x 2 x 2 x 2 in power = 16 in power).
The ear has a logarithmic sensitivity which means that it is very sensitive to low level noise (you can hear a pin drop), but much less sensitive to very loud noise (you can stand next to cannon fire and your ear will not be destroyed by the cannon report). This means that you can't easily perceive the progressive damage that very loud noise is doing to your hearing. For us woodworker this means - always wear noise protection when using loud power tools.
I got a bit wordy in this response, but I thought that it is valuable information to pass on.
>I knocked off close to 15 db when I installed a silencer on my big cyclone at work. It was a noticeable improvement, but it is still loud. Well worth it, I think. To get effective silencing, you need to dampen the exhaust air stream, not just the cyclone itself.
