Cast iron--- to tap or to bolt through with nuts?
Scott in Montana
>I'm getting ready to mount a 1/2hp power feeder on my shaper. Is it better to drill and thread the cast iron? Or should I simply drill holes and use nuts and bolts to secure the feeder?
I've been told conflicting opinions. Are cast iron wings difficult to tap? Is it strong enough? It seems to me that a threaded hole would be the cleaner way to go. If I use nuts and bolts extending through the wing I know I will have to be careful of webbing and other structural castings in the wing.
Please let me know your experiences.
Thank you,
Scott in Montana
Re: Cast iron--- to tap or to bolt through with nuts?
Bill Howatt
>I guess the strength issue is related to the size of the bolt and how much thickness/area there is in the cast being tapped. What I can tell you is that cast is easy to drill and tap since it contains a fair amount of carbon which acts like a lubricant - although I would still use some when tapping.
It does seem that a nut and bolt would put less localized stress on the cast particularly if a big washer was used behind the nut.
Bill
Lee Grindinger
I'd tap the top
Lee Grindinger
>The underside of these tops are ribbed and rough, a nut and washer probably wouldn't seat as well as you'd like since the underside of these tops are not flat.
More information
Scott in Montana
>You're right. More information is needed to get an informed answer.
First, I mistyped, it is a Delta 1/4 horsepower power feeder being installed on a 3 horsepower Delta shaper. I believe the bolts are 3/8".
Thanks again,
Scott
Fred Davis
>I bought a Delta stock feeder and using the boltys it came with bolted it to the top of my Unisaw and made a dedicated ripsaw out of it.
About the ribbing and roughness of the underside , it is a simple matter to check it out in the area of the feeder's base.
Worked for me and it's been on about eight years.
FredD
Rob Stokes in North Vancouver
>I'd drill and tap. You can always ream and use a nut/bolt later if needed.
Jesper, Denmark
Jesper, Denmark
>Go ahead and drill and tap. It is easy in cast iron and much easier to use than through bolting.
