We value your privacy.
>I can only offer a small poimter as I also drill mostly wood but Dad is the machinist. The biggest thing he told me was run your drill as slow as possible and use plenty of lube.
>I would drill one pilot hole first. Well, twenty pilot holes. A machinist once gave me his rule of thumb: look at the drill bit of the final size (in your case, 3/8). At the tip, there are two cutting edges that run from almost the centerline of the bit to the outside, and at an angle. These edges define the beginning of the flutes. The length of that cutting edge is a good diameter for a pilot hole bit.
In addition, it matters what kind of metal you're drilling. If it's steel, lubricant is definitely a good idea. Less important on brass or copper, but it never hurts.
VERY important: be sure the work is secured somehow. The bit is going to want to pick the work up and start spinning it around. Depending on the size and mass of the piece, it can happen much more quickly than you can move your hands out of the way. If the workpiece is small, I'd set up a secure stop on the drill press table somewhere for the work to butt up against, then use my hand to hold it flat on the table while drilling.
>The easiest way without buying more stuff is to centerpunch a dot where you want to start each hole. If you don't have a punch grind a point on a nailset & use that. Start with a pilot hole about 1/8", too slow RPM is better than too fast. You can use kerosene, 3-in-1 oil, or even WD40 for a lubricant. If the bit screeches or it takes a lot of pressure try or buy a different bit as the one you're using is either too cheap or too dull. Clamping the metal down is important, as the bit will grab just as it pokes through, or the metal may try to climb the bit. Practice a hole or two on some scrap first to get comfortable with the process.
>One thing that hasn't been mentioned is to use a center punch to make sure the pilot bit doesn't wander when starting. A good dimple to get started is all that's needed. If you're using a drill press, a pilot hole is less important, but it's always a good idea and I generally do it. Do clamp your piece to the drill press bed, or bench top if you'll be using a portable drill. Otherwise, the burrs will catch on the bit as the bit finally breaks through, and the piece will act like helicopter rotors, flailing away at anything in range, including you. They make a special high sulfur cutting oil for lubricating, but left over 10W30 in a squirt oiler works just fine for me. A drop before your start and a couple of spritzes as it's going keeps the bit from overheating and losing it's edge.
>I was wondering why no one mentioned a center punch. You can make one out of most any metal that is harder than the metal you are drilling. Use a steel nail (like you would drive into concrete) or even a case hardened cut nail. Just grind a point on it. Wear Eye protection while grinding and using the homemade punch just in case it shatters and little bits go flying. No need to ruin a nail set, unless you have one that is worn out.
