ADVERTISE HERE - FREE TRIAL
Cost of running Machines?
>I am curious about what it costs to run my machines. If a motor draws 10 amps at 240 volts and a kilowatt costs $.10, would the cost per hour be 10 X 240 or 2.4kw X $.10 or 24 cents an Hour?
Just wondering what it costs to run something like my Dust Collector or my TS for long periods of time?
Re: Cost of running Machines?
Bill Turpin in WNC mountains
>Yes, your calculations are correct. A motor that is not loaded will draw less.
>If you amortize the total cost of the floor space in the building where it's housed, the electricity to run it hardly counts.
Clint
Actually, what I was thinking about was....
>did it make sense to run a 1 1/2hp DC to pick up the dust off a ROS? Would it be better to make a down draft table out of a furnace fan. Clearly it is not really an economic decision. If I can run my DC for $.24/hour, it does not save enough to matter even if running the downdraft table for nothing. The other thought I had was not including a blower in the table at all, but to use the DC. One advantage to the DC is that the unit is outside the shop in an exterior closet. ALL the dust it collects is gone, outdoors, without regard to the quality of the filters. OTOH, so is the heat and AC. Running the DC in short bursts does not seem to have much impact on the heat or AC, but long runs do have an impact.
Jesse Cloud
>On top of that, my Oneida dust collector's manual said the motor does not like to be turned off and on a lot, better to leave it on if you are going to use it again in a few minutes...
Pete in Holland, MI
>Hummmmmm.......
Then with your DC outside the shop and no return air from that system coming back into the room, the room is going to be running with a negative pressure and drawing outside air in at any available location. If your room is too tight, your DC system may not be pulling as well as it could be.
>A motor pulls six times the current while starting as when running. Even though this lasts for about .75 seconds this does heat the motor. This is known as locked-rotor amps (LRA) compared to running load amps (RLA). Large motors do not like to be started more than about 6 times per hour. Restart times are listed in the specs for commercial grade motors. Hand tool motors, table saws, etc. are rated for more frequent starts.
>No chance my shop is that tight. It's a one car garage. The garage door is so loose snakes occasionally find their way in.
Does it makes sense?
>"...did it make sense to run a 1 1/2hp DC to pick up the dust off a ROS? ...."
Well if you're going to get all financial on us, it would be better to go to Walmart and IKEA than actually build furniture.
Happy Woodworking!
Speak'n of snakes....
Marv
>A rat'ler found it's way into my shop through a small hole at the bottom of my tilt-up door. It found a mouse that was leaving tracks in the sawdust, ate it, then couldn't get back out the little hole. The only reason I discovered it, it left a pile of black tar looking crap on the floor. I knew I didn't do it, so it had to be someone or something else. So I started searching around for the horrid crapper. I found it coiled up right next to the little hole it came in through. It met it's waterloo with the sharp edge of a flat shovel.
Yes, the hole is still there.
Marv
Re: Speak'n of snakes....
mike from american sycamore
>why did you kill it? Poor ol' creature....you should have set it free?
