Bloodwood
Bob in NE Ohio
>I just acquired about 15 bd ft of bloodwood and before I start fabricating, I was wondering if anyone has used this wood and are there any "Tips" you might have before I begin.
Thanks for the help
Bob
Bloodwood
Bob in NE Ohio
Thanks for the help
Bob
Re: Bloodwood
Dave Paine
>This is a very attractive wood. It is very hard and dense. It can tear easily, so sharp tools, bits, and small passes are recommended. Found this out the hard way.
I needed to cut a dado, and had tear out of the edges with a router bit. I ended up using table saw blade, which gave clean edges, even though I had to use several passes to get the dado width I wanted. I do not own a dado stack.
Re: Bloodwood
>Frank Klausz gave me enough bloodwood to make some beefy end caps for a workbench a few years back. It was the South American variety, not the traditional vermillion from India that I had used in the past (a relative of the padauks, Pterocarpus spp.). This bloodwood was hard, dense and interlocked but workable. It takes a high polish and will outlive me by many generations. I have reason to believe that it is fairly unstable until dry, but I have not tried a green piece for turning, so I can't gauge the shrinkage, twisting and warping properties.
What does "interlocked" mean?
Dan Mitchell
>I'm guessing a difficult grain pattern?
Interlocked grain
>Some trees grow with their vessels in nice orderly rows, running parallel up the tree. These are the woods that split with very little effort. Others have grain that seems to be woven together, switching directions continuously. Bloodwood -- at least the bloodwood I've worked -- falls into this category. When you try to hand plane it, half the fibers are cut smoothly and the others are torn up to some degree. Depending on the wood, interlocking can result in a shimmering appearance when sanded fine and finished.
Scraping
Mike Fitterling
>Bloodwood scrapes beautifully, leaving a shiny burnished surface. I would hesitate using sandpaper on it.
Cheers,
Mike
