Removable stair railing thoughts?
>Our church rents a truck trailer as a temporary storage unit for our large "flea market"/rummage sale.
Obviously it would be nice to have stairs - as the old ones have fallen apart. Not a problem. I would like to have a set of removable railings on one side or the other. The doors to the trailer are the swinging sort. Therefore the railing needs to be removable.
My thoughts were to use black pipe as the verticals and have them fit into something at the bottoms of the pipes (such as larger pipe). This would be attached to the side of the stairs. For the railing, I was thinking of using the flanges and suitable wedges to keep the rail slanted - though I could also drill holes.
TIA
Re: Removable stair railing thoughts?
Scaffolding fittings? Flatbed truck fittings?
>Surely the scaffolding industry has solved this problem already, since OSHA requires railings on just about any platform above grade. Might be pricey, but on the other hand - if my speculations are correct :)> - you'd have railings that would be a great defense in court when someone falls and sues the church.
If there aren't suitable fittings, or if the church can't afford them, my next approach would be to look into the fittings used to mount sides on flatbed trucks. In fact, since it's for a church, you might poke around local truck repair shops and see if someone's got some for free. Granted, these are often welded on, but not always. They're often designed for nominal 1" stock, so wedges to make the railings sturdy would be dirt easy - you could just pick up a handful of carpenter's shims at a lumber yard.
I'll go by the rental place and see what I can..
>borrow or beg.
