Power feeder: 1 hp enough for a shaper?
Brian C.
>Have a chance to pick up a used powerfeeder for my older powermatic shaper. Is a 1hp Delta big enough for that? Thanks for the help!
Brian C.
Yes, More than enough
Keith Newton------WebKitFormBoundaryV6MZb+tiOpocz6
>The gear ratio really ups the torque. You will probably be running it at a slower speed for the shaper. I have never had a problem with 1/3 hp, but it may be relative to the size of cutter and choice of wood, sharpness of cutter, and slickness of table and fence.
Re: Power feeder: 1 hp enough for a shaper?
Bill Earl
>1hp should be fine. I get by OK with 1/2hp on mine.
yes
jrutter
>Just echoing, I guess... 1 HP is the standard for industrial use, even on heavy shapers.
