The making of this piece
AndiWolfe
>Parturition No. 2 started on the lathe. I turned an egg form and used my indexing wheel to lay out longitudinal lines. Then I added latitude lines.
These lines were used as a guide for the design layout. Once I had the design on the form, I started carving away some of the negative space. I use rotary chisels for the initial roughing out, which requires a full face shield. After some space is made, I dig deeper as I start to shape the wings.
I'm using the NSK Z-500 for most of my carving these days. After the carving was completed, I did a bit of sandblasting and then some detail clean-up prior to adding Danish oil.
It takes a fair bit of time, patience, and concentration. The wings are about 2 inches deep or more from the middle third down to the base.
