DP Mobile Base and PM2800 Followup
Ken Bellock (Houston, TX)
>Last week I finished assembling the mobile base for my new PM2800 drill press and and finished installing the press on it. It was definitely a lot easier to install the mobile base on the foot of the drill press before assembling the entire thing. I made the base a little larger than the footprint of the drill press in depth, to account for the motor sticking out the back so far, and used large bolts to secure it to the base. I am very happy that I put it on a mobile base now. This weekend I was rolling it all around the shop as I organized all the large tools into their places in the new shop, and it was very nice to have everything on wheels! I was of course very careful while moving the drill press, but still did not feel at any time like the drill press was going to tip. When taken down off the wheels of the mobile base, the press is solid and doesn't move.
I haven't put too much time on the drill press yet, but I can still share my first impressions. None of the castings were broken, and all machined surfaces were flat and in good shape. Assembly was easy, but of course the directions were wrong in a couple places. The top was a bit heavy, but I was able to put the entire thing together myself. I would not recommend that though. When locked the table is solid, but the whole crank apparatus for raising and lowering the table feels super cheap. The teeth it rides on float loose in two rings on the column, and it just slides around no matter how I adjust it. The laser and lights that I thought were a bit gimicky are actually nice, except that with the terrible crank system, you will probably need to re-adjust the laser every time you move the table. The lights are not super bright, but nice to have. At 400rpm, the slowest speed... grrr... there is a huge racket coming from under the hood where the speed controls are. If I speed it up even a little to 430rpm, this goes away and things smooth out. The LCD for the speed display is always on, unless you unplug the machine, and when you plug it in, you can hear that electrical pop that lets you know it's sucking juice all the time even if it's off. That's fine to me though because all my tools are unplugged when not in use. I have too many tools that share outlets, and I have had to go through lightning strikes on a house before. I haven't been able to find the calibrating tools yet since the move so I have not been able to measure runout, but nothing is visible to the eye.
Overall I like the drill press, but if I had to do it over again, I would have bought something old and designed and made here in the USA.
Re: DP Mobile Base and PM2800 Followup
Fred Davis
>Ken,
send a copy of your email to PM, you will be glad you did.
FredD
