Gluing Ipe
Gluing Ipe
Gluing Ipe
David Winters
>My glue joint failed!
Freshly jointed, rubbed with acetone, slow-set epoxy. I have heard people having trouble gluing Ipe. Needs to be a waterproof joint. Maybe polyurethane glue?
Thanks-
Dave
Re: Gluing Ipe
Re: Gluing Ipe
>Why not Titebond Waterproof? And forget the acetone rub.
Clint
Re: Gluing Ipe
Re: Gluing Ipe
Ray Binnicker
>Mayby I'm just lucky. I've glued several table/bench tops up with Ipe. They were all 2x6 material, and in the 4 ft length range and 2-3 ft wide. I only jointed and glued up with Titebond yellow glue. I am using 2 of the bench tops now, one as a "sharpening" bench top and one as secondary work bench. After 5 years none show any signs of coming apart.
Ray Binnicker
Re: Gluing Ipe
Re: Gluing Ipe
Al
>I glued up an Ipe picnic table with gorilla glue and the joints started failing after one year. Reglued it with Titebond III and it's been good for 3 years now.
Re: Gluing Ipe
Re: Gluing Ipe
Pete in Holland, MI
>Fine Woodworking recently did an article on glues & woods. Titebond 3 worked better than epoxy on Ipe by a small degree.
