We value your privacy.
>Here is a curly maple box my son made with significant guidance from dad. The box is curly maple, the lining is walnut we cut off the family farm. We made the wooden hinges from some tibet he collected on St. Croix. The splines (keys?) and handle are also tibet. The top and bottom are book matched and the grain wraps around the box.
>I was surprised to find he had rusticated the hinges. They have a brass pin and are glued and pinned to the box with ebony pins. The mortises for the hinges are about a 1/4" deep. The hinges hold the lid open "just right", about 5 degrees past vertical.
>Thanks. My son thinks he made this box, but my recollection is that that there was a lot of father son bonding time in it.
The top and bottom are a piece of 1/8" plywood with a home made veneers of the curly maple on one side and walnut crotch on the other.
The panels were still under a quarter inch and five plus. I bought the curly maple at the WoodWorks show when it was in Richmond. Very nice piece of wood and I would have bought more in better times.
We laminated the panels between two pieces of particle board with plastic laminate on them as cauls. I have a friend in the cabinet business and he gives me sink cutouts from counter tops and I find endless uses for them.
My son finished the box with spray can lacquer (deft) from the borg.
That's gotta be about the nicest box I've ever seen in my entire life. Absolutely beautiful! Well thought out and every joint is near perfect. Beautiful wood too.
How long did it take you to build it? How much of it was done by your son and what specifically did he do? How old is he?
What kind of tools/machines did you use?
What is the finish?
Did you make any mistakes that are not apparent in the pictures? If so, would you like to share?
>I made them. Googled "wooden hinges" and got a tutorial. Basically, they are a finger joint with the fingers rounded off. We made about ten sets while we were making them. I have considered selling them, but probably would have to have thirty bucks for a pair.
Have to admit I like them. Got a post above about any experience with them. Would like to make them smaller and thinner, but the Fred Flintstone Engineer in me went for strength. There are a lot of possibilities for tapering them. Could also use on the front as a clasp/lift.
>My son is 24. A boomerang kid. He has been turning since he was about twelve and is better at it than I am.
We started with a 5/4 curly maple board about 4" wide and three feet long. My miter saw will cut a piece 4" wide, so that was a design consideration. I explained to him how to resaw the piece so that you can have the grain match all the way around the box. He did the resaw and cut the miters. He used part of the same board to slice off four pieces of veneer to book match of the top and bottom. While this was going on, I made about eight other boxes as Christmas presents. So he would watch me make a step and then use my setup for his box. There were all similar in size, but different. I had a walnut crotch I had chain sawed to sized and let dry for a year or two and sawed the crotch veneer for it. Made about a dozen pieces
and he used several of those in his box, including a small off cut that is the bottom of the little tray.
I had made a slider that rides on the fence of the TS to slice the slots in the corners. He used that on his box. I also made a jig that allows for the ripping of the key stock. The key stock is VERY sensitive to the thickness. Since we used the same blade to cut the slots, we ripped the key stock all at once to get the thickness right.
I kept thinking of more and more people that I could make a box for and the number kept increasing. One of my favorites was my cousin and her significant other. I made them a pair of walnut boxes with birch crotch wood tops. The wood for the boxes came form the same board and it was resawed and assemble so that no matter how you put the boxes side by side, the sides of the boxes were book matched and the tops were book matched also. An insane pairing. Sadly the couple has split up and each has a box. Didn't see that coming.
As the boxes were finished with cans of spray lacquer, Deft I think, from the borg.
The boxes I made as gifts did not have hinges. Before we assembled them we cut a rabbet on the interior, making careful notes on where the rubettes were. Then we sliced them apart from the outside, creating a groove around them and the tops sits on that, positioning it securely. I purposely left the groove around the exterior to 'celebrate" the join.
One of my responses above talks about laminating the top and bottom.
Working with your son has to add a lot to the memory of the projects.
I use the Deft spray lacquer on reconditioned saw handles. I like the end result but only if I steelwool the slightly bumpy surface and follow up with paste wax. I apply the wax with 0000 steelwool. I get a slightly shiney surface but not glossey. I prefer the lacquer for it's durability and resistance to the elements.
You and your son made a beautiful box. The hinges are very noteworthy to me because I never considered a hand crafted hinge for any box I've done--and, I've done a few. I love the tiger maple and the natural finish you applied: no yellowing at all. Really looks great. Now, whose is it? :<)
>Yes to the bumpy surface. Sand and clean the surface really well to minimize it, but the last step for my son on this one was to steel wool and wax it exactly as you described. Applying the finish is my least favorite part of the project.
You asked about mistakes and I forgot to mention one. Did anyone notice that one of the hinges is upside down? At least, one is one way and one is the other. This was my fault and I feel badly about it. We wanted to cut the hinges exactly the same size and have the pins exactly parallel and equidistant and all that. In a flash of brilliance, I inserted a longer rod through both hinges, forcing them to line up perfectly and cut them both at the same time. The looked perfect until I separated them and realized what I had done. I don't thing it matters technically and they work beautifully, but I was up set. We would have done it over, but it was the only pair of tibet hinges we had. They were made of tiny scraps my son had hoarded. Don't think he was as upset as I was. Dyslexia strikes again.
>He/we started the box before Christmas, but the project went dormant. About a week ago he went to Bonnaroo (Sp?) a big music festival in TN. Met a young lady from Australia living in FL. He is unemployed but she has a great job, so she bought him a ticket to come visit. She is now the proud (I hope) owner. Ain't youth great? He debated giving her a bowl he had made of Australian Pine he had salvaged after a storm in FL, but he went with the box. I was in favor of the bowl, leaving the box as a step up if things went well. Now what's he to do?
>Thanks Fred. You are right about passing on the skills. I taught him to turn when he was about twelve. Sneaked him into David Ellsworth's class at Arrowmont when he was fifteen. Had to sneak him in because you are supposed to be eighteen. David took me aside and said, "You know, we hate it when a father and son or husband and wife come together." I was astounded and asked why. "Because one of them is always better than the other." "So you are telling me he is better than I am?" "Umm, Err, Ah, yes." "I know that, I have taught him all I can and bought him books and videos, now lets see what you can teach him. Its a really good thing when the pupil surpasses the teacher." His sense of design is still better than mine.
My other son did not get the wood working gene. He managed to use the radial arm saw to cut about and inch off a clip board. You would have thought he built a credenza.
>The reason I asked about mistakes is because there is always at least one. No matter how careful we are and how hard we try to do everything perfectly, it just never happens.
Perfection is a myth. I have never made anything that ended up perfect. I used to get really upset with myself until it finally dawned on me that perfection isn't possible. Now I only pursue excellence, while knowing full well, there will be imperfections. And I'm ok with that.
As George Burns once said..."even God isn't perfect, he screwed up and made a crane's legs bend the wrong way."
>Tibet (sp?) is a tropical wood that my son and I both picked up on St. Croix and small pieces that would fit in a suit case and brought home on separate trips. Dark brown, rich looking. Beautiful. One of the oily tropicals that takes a beautiful polish. Really wish I had a lot of it. The hinges and accents on the box are tibet. I have walnut and will trade for tibet. Even two for one. Gorgeous to turn.
