Varnish for high chair
Todd in VA
>I need some help with some baby furniture I've been refinishing. My wife is due in mid July, and I've been refinishing the furniture my brothers and I used as kids. Most of it was nc lacquer that just needed minor repair and a topcoat. But the high chair seems to be a different sort of varnish. The finish on the high chair is beat up pretty bad, and doesn't seem salvagable. Any suggestions for what I should be using for the high chair? I would like something tougher than oil or shellac. I have spray equipment, and I'd prefer to use it to a wiped or brushed finish. Thanks for any help!
Re: Varnish for high chair
Fred Davis
>Todd ,
if the chair is all wood including the tray , I would use Watco - Danish oil for the simple reason , it is very easy to renew and film finish on something that gets the treatment a HighChair does , seems like a lot of work for nothing.
FredD
conversion varnish
Bill Tindall, E.TN
>If you spray then this is a material you should have in your arsenal of finishes. It is hard and durable like urethane varnish, but dries almost as fast as lacquer. I use Sherwin Williams Kemvar, but every finish company makes a similar product.
Howard Acheson
>Just plain oil based varnish or poly varnish would be fine. Clean up the surfaces by sanding and then wiping down with mineral spirits to remove any gunk. Pay particular attention to the tray upper surface. Apply a coat of dewaxed shellac to to create a barrier to any residual contaminates that are on the surfaces. Then apply a couple or three coats of varnish. I did this to a used high chair for my grand daughter six years ago and it's being used now for my 8 month oil grand daughter. All we did this time around was to scuff sand the finish on the tray and arms and apply another coat of varnish. Looks good as new.
It takes oil based finishes 3-4 weeks to fully cure and develop full adhesion and protective qualities. But, you will not be needing the high chair right away.
I would not recommend an oil/varnish product like Watco, etc. These are not very water and abrasion resistant. In other words, they will not stand up at all to frequent washing with any type of chemicals. Water and juices will quickly penetrate the surface causing stains that will not be easy to remove. Neither shellac, NC lacquer or waterborne finishes are as durable as standard oil based varnish or poly varnish.
Fred Davis
>"The finish on the high chair is beat up pretty bad, and doesn't seem salvagable."
Exactly, it had a film finish on it.
I use CAB Lacquer on wood items like Kitchen Cabinets and Furniture not subject to abuse other then normal wear and tear , nearly 100% of the time.
For items like my Oak workbench top which is subject to abuse that no film finish would hold up to , I used Watco -Denis Danish oil and Minwax Furniture wax on it.
This top is now five years old and looks nearly new, for the simple reason , it is easily maintained unlike film finish.
It will bead up water, feels and acts very smooth , hence it is resistant to dirt.
Film finish looks great when not abused and you said it was "pretty bad" in the Environment a high chair would encounter.
So I think if the flat to Satin look of oil pleases you , you will find it a pleasure to keep looking that way.
If you opt for the oil finish , it is important to sand down the wood to as new as you can get it for the oil to penetrate.
FredD
Todd in VA
>Big thanks fellas for all the help. I really appreciate it!
Lee Schierer - McKean, PA
>My father refinished a high chair and used polyurethane for the finish. It has survivied 3 grandchildren so far with no problems. I would not recommend an oil type finish as teh kids will tend to eat stuff they drop on the tray.
Lee
