OT - Funny way to mount tires *LINK*
>I saw this on a dirt bike forum that I frequent. It doesn't seem that it works on motorcycle tires, but peopel say it works on larger 4x4 and tractor tires. Judging from the number of related videos of people doing the same thing, I guess it's not that rare.
Happy Woodworking!
http://www.youtube.com/watch?v=JqFmM5gDAr8
Re: OT - Funny way to mount tires *LINK*
Justin Szeliga
>A friend in high school back in the late 70's talked about seating truck tires with ether. Little too much, & you have a bit of a problem. He liked the ether too. There's no way to make things 100% safe. Every once in a while someones always gonna die uttering the famous last words of a redneck, "hey ya'll, watch me do this".
Gerry Wittenberg in North Surrey
>That method of inflating obstinate truck tires has worked for me on several occasions. I would NEVER use ether in an enclosed area, you can never get the 'dose' just right. I've had an 1100 x 24" truck tire launch itself 12 - 15 ft straight up and I've blown the sidewall out of a 22" readymix truck tire. It is certainly not an approved method of seating truck tires but when all else fails.............
Jason Roehl in Lafayette, IN
Another way...
>Though I've not done either method, I've heard several who swear by wrapping a ratchet strap around the center of the tread, then tightening it, forcing the beads to seat.
But explosions are so much more fun.
Jason
It works
Lee Schierer - McKean, PA
>I've renflated tubeless lawn tractor tires with the ratchet strap trick. It works.
Lee
Re: It works
Tony - Memphis
>Worked on my wheelbarrow too! Then I filled it with green gunk and it hasn't leaked in years.
Tony
Old and well established method, yes
>When I did tires a million years ago (1965 and on for a few years), we had a "strap" that consisted of a very flexible air hose with a strap attached to it, and one of those double-ring tension devices. We'd tighten it up as much as we could, then inflate the air hose. Worked a treat. We also lubed the bead, to make it easier for the tire to slip over the rim.
>I recall a while back the truck places had to buy cages to do their tire mounting in because there'd been workers injured by tires getting out of control while being mounted. This looks like one of the illustrations for the definition of idiotic to me.
John E in SC
>The cages for truck tires are mostly for split-rim type tires. Some older truck tires had a metal band that slipped around the rim and was held in place by the inflated tire. Sometimes while inflating the tire, this would pop off, and usually seriously injure the arm that was holding the air hose! (I grew up working at my Dad's service station, so I've unfortunately seen it happen.)
We never used the ether trick (never had to with car or truck tires), but I did resort to it a few years ago. The air in the rear tractor tire on my John Deere got low, and when I hit something with the sidewall, it just popped loose. I spent the better part of half a day trying to get it to reseal, including rachet straps, lubing the rim, taking out the valve stem, and anything else I could think off. Nothing even came close. I finally went to Tractor Supply to buy a lug wrench big enough to remove the tire so I could take it somewhere to get fixed. Happened to run into a friend who works with heavy equipment. When I told him my trouble, he suggested the ether trick. When home and tried it - worked like a charm on the 2nd attempt. Sure wish I had thought of it earlier. Would have saved me a lot of grief.
PS...
John E in SC
>It's probably safer to do this if you take the valve core out first - that way any excess pressure can relieve itself out the valve stem. You just have to be fairly quick to get an air hose on it to add some air pressure to keep the tire sealed until you can get the valve core back in.
How does it work?
Alex Grigoriev
Re: How does it work?
Hank Knight
>Starting fluid is ether which is very volatile. When it's ignited, it explodes. The rapidly expanding gasses from the explosion force the tire against the rim, sealing it.
jared
>This is a common way to seat the bead on truck and grain wagon tires around here, northwest Iowa. I have seen it done many times. Supposedly John Deere ether is the best to use because it has a higher percentage of actual ether and exlodes better. There was an incident locally here last winter where a guy was doing this on a truck tire and attempted to light the ethere with his bic. Not being too bright, he had his hand to close and when it went off, the tire expanded pinching two of his fingers in the bead. That would be bad enough but it didnt quite seal off the bead because his fingers were stuck in there and it created a gap where all of the hot air from inside the tire was escaping so it in effect cooked his fingers after the bones were already broken. He ended up having a couple of surgeries to repair the bones and muscles.
Alex Grigoriev
>That is it's done after the tire is fully on the rim, two sides?
Yep.
John E in SC
