3 rid post on doors.
>Here is the door, repaired and Primed.
After the epoxy cured, I belt sanded the patches smooth and primed the doors. I will return them and the owner can paint them.
One of the doors was so rotted that when I routed away the damage to the bottom rail, it fell out. I planed it down to a 1/4" and reinstalled it on the inside with 1 1/2" of walnut on the outside.
In every case, the dowels were either termite bait or wood prone to rot. Almost none of them survived. In the case of the rail that fell out, I drilled in through one stile and drove in dowels. The other stile had enough wood left to create a lap joint.
