2nd post on doors.
2nd post on doors.
2nd post on doors.
>Should have posted these in reverse order. Here is the door with a number of walnut patches in it. I used walnut because I have it and it is decay resistant. The patch is in about eight pieces. First I routed out most of the damage and filled what was left with Bondo. Then I routed the bondo smooth. Before adding the Bondo I soaked the damaged area with BoraCare to kill any remaining rot. Then I soaked it with Minwax Wood hardener. I cut pieces and fitted them on multiple layers, overlapping them, building lap joints to return the strength to the frame. I use epoxy for the glue because it is water proof and has good gap filling ability. Lots of epoxy. Some of the patches are 1 1/2" deep and three layers of 1/2 wood, some are 1" and some 1/2". Any remaining voids were filled with epoxy and Bondo.
