Have a question? Ask Woody!
Repairing Exterior French doors
>I posted a while back about repairing some exterior doors that had rotted. There are four of them. A pair that are hung as French doors and another pair used as side lights and fixed in the frames. Two had rotted badly. One had been damaged by termites and the fourth one was nearly undamaged. The undamaged one was the active door and I believe it survived best because it was cut off at the bottom and free to dry out. The Other panel that was hung on hinges was too close to the threshold and could not dry. The seal to the glass failed and water leaked into the door from the bottom three panes. One of the fixed side panels had been found by the termites. The other had rotted from the bottom up because it was sitting down in a track or groove that trapped water.
The first picture is the termite damaged door after I routed away most of the damage and filled what I could with Bondo.
