Scantling? What's a scantling?
Stephen Kirk in Quakertown PA
>I'm looking at an older text on gates and fences. The author refers to construction of his gates and states that the end piece of the gate should be 4 by 24 scantling. I thought that scantling meant "square", but a 4" square end piece is huge, nearly the size of the post it is hung on. So I thought maybe my interpretation was wrong.
Anyone know what this could mean?
Re: Scantling? What's a scantling?
Jesper, Denmark
Jesper, Denmark
>http://en.wikipedia.org/wiki/Scantling
Lee Schierer - McKean, PA
>As I recall my grandfather's use of the word,he was a carpenter, it referred to any thin material name 1 X ?? or 2 x ?? stock. Anything else was a timber when referring to thicker stock. That was many years ago, so my reccolection might be fuzzy.
Lee
Jerry Gibbs
>In boat building, it refers to the general dimensions of the materials. A boat could be referred to as having heavy or light scantlings. Jerry Gibbs
>So, seems like I was right in my thinking that 2 by 24 scantling probably probably means 4" square by 24" long. That's a bit bigger than I was thinking, so I'll probably just adjust to what seems right to me. Of course a 24" high gate probably isn't going to keep much in.
Ah, the fun of trying to translate old texts, even if they are in English!
Jesse Cloud
>I googled the definition and got answers all over the map:
1. A very small amount; a modicum.
2. A small timber used in construction.
3. The dimensions of a building material, especially the width and thickness of a timber.
4. Nautical The dimensions of the structural parts of a vessel. Often used in the plural.
5. A upright in house framing
Something's Been Lost
>in the "translation." Using a 24" 4x4 on a gate end makes no sense, especially if the fence is higher than 24". My grandfather used the term to reefer to the overall dimension of the object; a table's "scantling" might thus be 42x72 in describing its top size. It is also possible that your author was referring to a gate being 4 feet high by 24" wide making it a bit narrow, but high enough. Your text may simply be a misprint of the original.
Now, of course, the language has dropped the archaic word because the numbers alone accurately describe the overall dimension.
Were I you and seeking to replicate the author's plan without diagrams, I'd extrapolate from the fence's other dimensions and specifications that you understand.
To all ye who would dare to enter the realm
Art Silva
>of boat designers or builder/repairers (shipwrights), had best be prepared with Dave Gerr's great work: "Elements of Boat Strength for Builders, Designers and Owners." As per Mr. Gerr; "Simple scantling-rule calculations for strong,durable hulls, decks, and other boat parts made from fiberglas, wood, wood-epoxy composite, steel and aluminum". His scantling formula is derived from LOA(ft.)x BEAM(ft.)xdepth of hull at midships from shear to top of the keel inside the hull all devided by 1000 = scantling number. Without getting much deeper it allows the designer to determine the height, width and length of ribs, frames, planking, etc. for monohulls from 10' to 120' with a design top speed of 45 MPH. Hey Steve, how come you did not ask me this question at the Guild meeting tuesday night? Semper Fi! Art
AN D
>Good Afternoon Mark,
....add 30 cubits.
George
Riiiiiiiight
>What's a cubit?
Re: To all ye who would dare to enter the realm
>After your answer, now I don't understand the question.
I hadn't read this before the meeting! 'Sides, I was too busy answering questions about the spice box.
Chris Friesen
>According to Charles H. Hayward, a scantling is any smallish piece of wood that is 2" to 4 1/2" wide and 2" to 4" thick.
From the same author, a "strip" is less than 4" wide and less than 2" thick, a "board" is more than 4" wide and less than 2" thick, a "batten" is 5" to 8" wide and 2" to 4" thick, and a "plank" is 11" wide or more and 2" to 4" thick.
