Dehumidifier "troubles"...
>My old Hampton Bay has given up the ghost. My newer Whirlpool (now 2 years old) is not really pulling water from the air - though it is running a lot (and it is quite noisy - even more than usual).
So - repair (if so, where) or replace (any current favorite models)?
Re: Dehumidifier "troubles"...
Re: Dehumidifier
>Basically, IMHO, run 'till they drop (which ain't as long as it used to be) and then buy a new one. Repair (parts and labor) usually costs more than a new unit. Hampton Bay (Home Depot) were made by Fedders, now OOB, but parts are available. I had two. Replaced the humidistats in both [@$30 each]; one went DOA, the other limps along provided the temp in the basement doesn't drop below 50� or it will freeze up.
Based on CR ratings and tests, bought a Danby 60-pint last year. Thus far it has done well. Tank is a bit small so I have to empty it 4-5 times a day, and it does throw a fair amount of heat. It does work to lower ambient temps that the others, and doesn't freeze up. Between the two units in my basement, I take 10+ gal of water out each day to keep my basement office and shop under 65%
Two tests before replacing
Lee Schierer - McKean, PA
>First of all, unplug the unit for 10-12 hours and then plug it in again. Icing up is a common fault. The fan runs, but no water is removed. See if the air being blown out is cooler than the roof air.
Second test is to insure the control setting is for maximum humidity reduction. It is easy for teh settings to get off. You should be albe to hear the fan and the compressor cylce on and off as you adjust the control.
As an option, consider central air conditioning. We added A/C to our house last year via a geothermal 2 stage variable speed fan heat & A/C unit last summer. We ran the A/C July, August and September 24/7 and used the same KW as the previous year running window and room fans and a dehumidifier. The house was a constant temperature and the basement had never been drier.
Lee
OK, will do the tests
>but I don't usually run the AC. The basement is typically cool enough, it just is humid in the summer.
BilWil
>I repaired one, new fan motor, recharge the coolant, new thermostat and cleaned out the rust and dirt. Total expense was $75 plus my time. The unit lasted another 7 months and rusted out to the point it leaked all over the floor. The LOML pointed out that by the time we added the expense to find and buy the parts and added in my time to diagnose and fix the 7 months of additional use came to a cost of $25 per month. Don't you just love it when she is correct??
Norb Schmidt - Cumming, GA
>JL - dust got my GE - the compressor still works great by the fan motor died - its a simple C type two speed motor, but the replacement part costs $60 plus shipping, so I went new. Too bad these are throw away now - my parents are still using their GE and it has got to be pushing 30 years old.
Anyway - if you want the unit to try and salvage - you're more than welcome to it. I'd love to come out and visit, would love to see your chairmaking set up anyway.
BTW: I still have miles of film - I'll never run out. Thanks
Norb
