OT Ceramic Tile & Concrete question
Nat Robison
>If you were to apply tile to a concrete block wall, should the block be stripped of paint for better adhesion or is the paint not a factor?
Re: OT Ceramic Tile & Concrete question
Curly Smith
>The surface must be porous if you're going to use thinset or mastic so you'd need to sandblast or strip the paint. Construction adhesive might be an option (and you'd need to caulk instead of grout) depending on your tile and how much you have to cover, but sandblasting is quick and fairly cheap.
Use latex modified thinset, It'll stick
Fred Davis
>You will find that the concrete block wall's flat appearence is deceptive once you lay a tile on it.
This would be a plaster job with the tile set in the wet plaster or thinset used if you let the plaster dry.
Of course the plaster is a trowel trade and only professional tile setters or plaster people own the skill to get it right.
FredD
Nat Robison
>Thanks for the tips. I'm helping some friends finish their basement and the landing at the bottom of the stairs is about 37" by 37" so I can't frame it in using conventional techniques or it will be smaller than the code-required 36x36. I don't want to do furring strips either since that will encroach too far as well. I was think more along the lines of faux brick or something like that which wouldn't require a dead flat surface.
I'll look to at least strip the paint and do some tests.
Tongue in cheek?
John in NM
>Nothing special about plasterwork, just takes practice. Gypsum plasters are easiest to get smooth if you can work fast, lime dries slow so you have lots of time to noodle with it, though lime is more prone to cracking. US Gypsum Structolite is a nice slow curing gypsum plaster that would make a good base for tiling an uneven surface. Let it dry and use thinset as Fred says. I think thinset would sag too much to use it to even out the wall by itself.
Re: Flat Wall
>You should be able to "resurface" and then tile that wall with 1/4" hardiboard that you screw to the existing masonry, then use thinset and tile all under a total inch of addition to preserve your 36" minimum.
Why are we overworking this question?
>With or without the paint, the block has plenty of tooth to hold mastic or thinset. I have set tile directly to painted drywall with modified thinset or mastic, and it's never fallen apart, even on the ceiling of a shower. In this case, mastic will be the easiest way to put it up. I guarantee it won't come down.
Clint
