This is a crass commercial announcement...........
Art Silva
>On May 5th. in 1999 Louis Iturra of Iturra Design in Jacksonville, Fla. mailed me a 1/2" x 105" Lennox Promaster-#3 carbide toothed bandsaw blade. As I have mentioned many times on this site, it was the best performer of all the many bands & brands that I have used, and I recommended its prowess and durability non-stop. I told many people with 14" saws that this blade was the "Gorilla" in the corner. Anything that I could lift on top of the table got cut. It proved that a great 1/2" blade was all that was required to turn my 14" Delta saw into a resaw giant. Of course it still needed some help with a stiffer tension spring, and Louie's special Bandroller Guides and maybe a few other of Louie's goodies, But the blade was the star of the show!
At 10:AM this morning the music stopped. While re-sawing a 4" piece of prime Penn. black Cherry the blade broke. The noise that accompanied the break, and the vibration that ensued stunned me for the moment but I shut the beast down and collected myself. I opened both doors and removed the blade. It was a clean break. I turned the top wheel and inspected the tire and it was OK. I then started to turn the bottom wheel to inspect the tire and the rumble and the noise surprised me. I removed the access door and discovered that the motor pulley was at an angle, and almost off the shaft. The red Loose-Link belt was the only thing holding it on. The motor is a big cast iron 1 HP Baldor that I had replaced the 3/4 HP Marathon motor with back in the late eighties. The Baldor was new, but it had no key, so I had to use the key from the marathon. I discovered that the shaft key had split diagonally down the length of the top of the key througth the set-screw hole, and the left side of the key was split
off, causing the pulley to try to leave the scene. All the hundreds of 220volt starts of that big Baldor over the years did a number on the key.
Ladies and gentlemen woodworkers, this high mileage, carbide toothed blade did not break because it was tired, it broke because the shaft key gave up the ghost.
Louis Iturra's catalog states that these blades will outlast carbon steel blades by a factor of 40 times. I can vouch for that claim.
I shipped my blade back to Louis this afternoon for repair, and he is sending me a 3/8"x.032" Vari-Tooth form 3 to 4 TPI to test drive and write a report. Stay tuned. Art
P.S. A while back a Domain Bandit pirated Iturra Design, and registered, thereby depriving Louis of his own brand name and he wants a lot of money to sell it. That is why Iturra changed his phone number to 904-371-3998. Do not google Iturra Design, because the freak that stole it makes money off all the names he has pirated. Please continue to support Louis and his company.
Thank you folks. And now for the disclaimer: I have no piece of the action with this company, and the only vested interest that I have is that Louis & Lynn have become good friends of mine over the years, and this company is the culmination of their efforts to build a successful business and serve a clientele that appreciates honest products that perform as advertised.
Re: This is a crass commercial announcement...........
Woodie49
>Do they have a web site?
Re: Learn to do Business in 2009....
Bob Entwisle in NJ
>I love the Iturra Design catalog, it truly is a significant body of bandsaw knowledge.
But,
"P.S. A while back a Domain Bandit pirated Iturra Design, and registered, thereby depriving Louis of his own brand name and he wants a lot of money to sell it. That is why Iturra changed his phone number to 904-371-3998. Do not google Iturra Design, because the freak that stole it makes money off all the names he has pirated. Please continue to support Louis and his company. "
It seems ridiculous to me for a WC member to post details of how Ittura was victimized by a Domain Bandit, and as far as not goggling Iturra Design, well that is just Stupid.
While I will support Luois and his company, and even sort of like the ornery resistance to the web and new technology in principal, a word of advice to Luois is, it's 2009, and time to exhibit a web presence, even if it is just an "email me here", or call this number for more info.
My 2 cents
others agree, other options.....
Bill Tindall, E.TN
>We have had numerous reports from others raving about the Lennox carbide blades. We had the Lennox person in for a club meeting last month to discuss blades and band saw set up. Any modest sized city will have a Lennox dealer. I use Misenheimer in Morristown TN , for example. This, and other, blades will be available locally if that option is preferred by someone.
When buying a carbide blade the cost of the blade is mostly determined by the number of teeth one is buying. So a 1 tpi blade will cost about half of what a 2 tpi blade costs. Lennox makes a great number of carbide blade options. If your knees go weak at the price of a 3 tpi blade, you could consider one with fewer teeth. The cut may not be quite as smooth, but perhaps that may not be important. The cost difference can be substantial.
Another issue in cost is where blades are bought. The woodworking supply places seem to be the highest price. A 1/2" steel Lennox blade for a 14" saw from Misenheimer is about $6 and blades for larger saws $10-12. A carbon steel blade from a retail woodworking store could cost a significant fraction of the cost of a carbide blade from a industrial supplier.
Dick Coers
>"It seems ridiculous to me for a WC member to post details of how Ittura was victimized by a Domain Bandit, and as far as not goggling Iturra Design, well that is just Stupid."
Get up on the wrong side of the bed today Bob? A bit harsh I would say!
wilbur
>I think that the issue of the domain bandit is a moot point. www.iturradesigns.com and www.iturradesigns.net are both available for registration. So are www.iturra-designs.com and www.iturra-designs.net, and just in case I have the spelling wrong, www.itturadesigns.com, www.itturadesigns.net, www.ittura-designs.com, and www.ittura-designs.net are also all free for the taking.
You can check to see if a domain name is free by going to www.networksolutions.com (I'm not affiliated with this site). If so, they will be happy to register the domain name for a whopping $9 a year.
Perhaps my admonition to not visit Google.........
Art Silva
>to find Iturra Design should have been more to the point, but it was late and I thought I made my point. The fact is, there is a lot of information there, but none of the sites take you DIRECTLY to Iturra Design.
There is no doubt, that a good Web presence is a definite asset to building a successful business, but as with many start-up companies the priorities are money, product, money, energy, money, time, etc.. By the time Louis turned his attention to the Web, his name was already stolen.
Name is not stolen
wilbur
>See my post above.
THANK YOU, THANK YOU WILBUR......................
Art Silva
>I just called Louis and he is going to check it out. Thanks again. Art
Re: others agree, other options.....
>Bill, would a 1 tpi blade be suitable for a Delta 14" bandsaw with a riser? for resawing stuff five to twelve inches wide. Should have looked, did not know they existed.
Re: Agree with Bill...
Glenn Madsen near San Francisco
>The local blade and sharpening fellow is light years ahead of the wood dorking stores here. What he sells is expertise. What they sell is something else, to another audience. Not that that is bad, but it isn't me very often any longer.
Shrink wrapped doesn't do it for me much any longer.
Support your local guru. And get better products at lower costs.
I don't know
Bill Tindall, E.TN
>The Lennox tech service person suggested a 1.5 tpi blade for our 20" saws if we didn't need the smoother cut of the 2-3 tpi or 3 tpi blade. Cal Lennox and ask. It all depends on the bade thickness. Thicker blades don't like to roll over smaller wheels.
Re: This is an appology........
Bob Entwisle in NJ
>Art,
I did misunderstand your reason for saying not to google Itturra.,
I apologize to you and everyone else, and especially Luois Ittura, if my post seemed harsh, (I actually agree it probably is a bit/very harsh sounding).
In my efforts at attaining world class curmudgeon status though, I think I added a couple points to my scorel.
My concern is really for the continued success and existence of Ittura Designs, and while I love to hold the catalog in my hands to read it on paper the way reading should be done, Ittura would do well to forgo one issue of the printed catalog and sink that cash into a good website.
As Wilbur discovered there are several available domain names, and I�m sure that the cost of developing and maintaining a web site would be made up in increased sales.
How many folks on WC don�t order tools and equipment online?
Again, my appoligies for ruffling anyones feathers, and hopefully Ittura designs will get on the web.
Bob
Re: That was an apology........
Bob Entwisle in NJ
>spell checking is next on my list........
Apology accepted. As a former New Jersey.........
Art Silva
>resident I realize that there are days when the companies that pursue "Better living through chemistry" in the state can fog the thinking process, to say nothing of the sinuses. Semper Fi ! Art
