Question on Makita 14.4 Cordless Drill
Ralph Lipeles
>This weekend I used my Makita 14.4 cordless drill for the first time. It is a model 6333DWAE that I got used. I was building a pergola for my son. I was driving 3" coated, flat head, screws into pressure treated wood. The drill performed poorly. It barely drove the screws flush into wet wood. When going into drier wood,(recently purchased but not "wet" with the pressure treating) the screws only went in about 2". The clutch setting was at it's highest. I switched to my 8 year old Dewalt 12V cordless and it did great. The Dewalt easily put every screw head beneath the surface. My question is whether the Makita drills are gutless or do I have a problem with the slip clutch. Any help is greatly appreciated.
Re: Question on Makita 14.4 Cordless Drill
Bob Entwisle in NJ
>I don't have a makita, but it sounds like a battery problem to me.
No reason a 14.4V drill shouldn't be able to sink those screws.
If one or more of the cells in the battery are shorted, as ni-cads are prone to do, then you are not playing with a full 14.4V battery.
My 12 year old dewalt 14.4 is still going strong.
Re: ? on Makita 14.4 Cordless Drill
Joel M. Dibbern-Kramer
>I have the Makita 14.4 cordless drill, model 6333D (I am sure a older brother to the 6333DWAE) for approx 5yrs. now. The batteries that power these units are Ni-MH 14.4v 2.6Ah batteries. With this combo I have driven six inch course thread screws into pressure treated wood with no problems (do not remember if wet or dry, memory fails me). This sounds (as a previous writer/post stated) one of the battery cells has a short in it. I would check the voltage on the battery. Note: there will be three or four leads, the plus & minus terminals should be marked. If not take note in the drill itself to note which terminals are the correct ones to hook up the VOM to.
Unbiased plug: I have never had any problems with any of the Mikita cordless drills that I have had, starting from the old 7.2v drill. Just one actually the batteries eventually fail, but that can be said for all the cordless tool mfg's.
Bill R
>I agree with the other posts. It sounds like a bad cell in the battery pack. I have never had an issue like that with my Makitas. Also work with 10-12 14V Makitas at the non-profit boat shop where I volunteer and have never had an issue with any of them either.
Opposite for me
>I have a bunch of cordless NiMH drivers with 2-4 batteries for each.
My 12 year old DeWalt 12V batteries are useless. The 6 year old DeWalt 12V batteries are just about useless. The 4 year old Panasonic batteries are pretty close to useless. But my 10 year old Makita 9.6V is the only one still going.
I've since given up on NiMH batteries and got a couple of the Li-Ion Milwaukee 12V which so far are much better.
Happy Woodworking!
>I have a 12 volt Makita drill. Actually, I have three. One is about twelve years old, and one about seven. I bought the second one in a combo pack with an impact driver, because the batteries for the first one were going bad. Caught the combo on sale for about what two batteries would have cost. The third one I bought for $20 at Home Depot because somebody stole the charger and batteries. Other than the batteries wearing out and failing there is nothing gutless about any of them. For shop use, I like the 12 volt size because it is lighter and smaller than the higher voltage units and has plenty of power. Recently built a huge porch for a friend and used the drill and driver all day long driving 3" screws. No problem. I think the others are right. You probably have a bad cell.
OTOH, I hate those @#&^%$ batteries. They are expensive, heavy, and only have about five hundred cycles. We need a serious improvement in batteries. The L-ion are supposed to have significantly more cycles (1500????), so lets see how they do. Just hope they don't explode and burn the house down. (That really happened)
Re: Question on Makita 14.4 Cordless Drill------We
John in Calgary
>Definitely not gutless. How long since the battery was charged? I've found with the NiMH batteries, since I don't use them every day, they'll discharge while sitting and I find that I need to pop it in the charger before using them the first time on a project. I have 3 batteries for this reason - one for the drill, one for the impact driver and one to rotate into whichever unit I'm using when I find the power disappears.
If this was right after charging, then you probably have a bad battery. I found a couple of places on line that sell no-name 3.0 MAH batteries for the $40 range that seem to work fine for my handy-man needs
John
Slip Clutch
Ralph Lipeles
>I checked the battery and then tried to drive some screws again. This timew I paid more attention and think that the problem is with the slip clutch. It will drive the screw 1/2 to 2/3 of it's length and then slip. I stop the drill and retry. Now it goes further before it slips. I repeat and can bury the screw head. Anyone ever disassemble and check out a slip clutch?
Re: Slip Clutch
>Ralph, I almost never use the slip clutch for driving big heavy deck screw. Just put it in the drill mode and have at it. You have to pay attention, but you have to anyway. The wood varies enough that if you sett he clutch high enough to drive them reliably, it will over drive the ones that hit soft spots.
Where the clutch pays off for me is driving delicate screws. Fabulous for installing electrical cover plates. Put it on 1 or 2 and go all day. I even find its great for small brass hinge screws. Keeps me from getting heavy handed and shearing off a screw.
I would not try to take apart the clutch. I would let the magic out and it would never work again.
GalenV in Iowa
>Ralph;
I looked up the Makita and it says it has 17 torque settings and a drill settting. How will it function not using the torque settings?
It says it only has 330 in-lbs of torque so not a biggy for a 1/2" drill. Says it has two speed 0-400 and 0-1300 RPM. It list the wood capacity as 1" so green timbers and long screws a strain it sounds like.
You did not give the Dewalt drill model to compare. You might look it up and see how much diffference there is.
When my last battery operated drill gave out I bought a new one and when I got it home the gears sounded like they were going to stip. Took it back and went back to my old corded drills and happy ever since.
Galen
