Ductwork
Doug Ridley
>Okay, I've got all my ductwork up. Now seal with duct tape or just leave it alone? I don't want to glue it and it seems pretty tight with just the PVC fittings. Is that sufficient or not? What do you do?
Doug
Ductwork
Doug Ridley
Doug
Re: Ductwork
>I have not sealed mine (also PVC). I have not detected any leaks, but have done nothing scientific searching for them. I don't hear any hissing and See no dust tracks that indicate leaks.
OTOH, I have found it quite handy to be able to take the system apart. For reasons that are not clear (OK, I'm and idiot) I sucked up a plastic bag. It lodged in the impeller and made a terrible racket. I just pulled the fitting loose and reached in and pulled it out. That bag will never hold water again. Occasionally something gets caught in the system and I can get it out. And then there is the chance I will add tools or rearrange the shop. I have made a few minor changes already. I had a gate that I pulled down to open. Did not close well. Swiveled the pipe so that it now pulls up to open and gravity helps the springs close it.
Fire up your system and if you think you have leaks, you could test for them with a smoke pencil (cigarette) or any small source of smoke.
If I sealed the pipe at all I would use really cheap caulk on the rim of the fittings to make it easy to take them apart later.
Re: Ductwork
Dave Paine
>I have not sealed my ducts. A dust collection is high flow, low head, so not so likely to leak.
Personally wanted the ability to dismantle if needed.
Some legs I used PVC electrician style tape, but this is where I had a vertical flex hose leg coming into the PVC fitting and wanted to ensure it did not drop out.
Make your own decision, but I expect even if you seal, the volume suction difference will be negligable.
Re: Ductwork
Paul Cates - Henderson, KY
>I was concerned about the joints coming lose over time, so I used shiny aluminum tape (it adheres better than duct tape, IMHO) on each joint and drew a small line with a fat Sharpie across the tape and pvc...nothing has moved. The DC sucked up a rag that caught on the impeller, thus I had to dismantle a few joints to get access to the impeller.
Sucked up a plastic bag? Sucked up a rag?
Scott in Montana
>Amateurs!
Mine sucked up the title to my new car that I set on top my bench for just a moment. My dust collector is SO good that it didn't even plug the impeller... it just shreaded my title into pulp. :O)
Scott in Montana
Re: Sucked up a plastic bag? Sucked up a rag?
Doug Ridley
>aLL THESE ANSWERS WERE JUST WHAT i THOUGHT. tHANKS TO ALL.
dOUG
Amateurs?
>One of my screwdrivers [minus type] got too close to an intake shortly after I changed to 6" PVC [alu-taped joints]. Hit the impeller with a satisfying WHAM BAM SCREEEEEEEEE and then punctured the exhaust hose. I had a welding shop straighten the impeller blades, but, alas, the vibration gradually increased over about a month's time 'til the motor bearings went. Swapped out the blower with a new Penn State 2hp /12" unit. Now I don't let the cats into the shop when the DC is in use.
Re: Amateurs?
Kneale Brownson..Awaiting return to CO snows
>Your cats play with your screwdrivers?
My Cats
>play with whatever strikes their fancy. Anything not "put away" is a toy.
Re: Ductwork
Dave Bair, Eaton Rapids, MI
>I joined mine with just the pvc primer, on advice from I don't remember where. It worked well for about 3 years but has started leaking at several of the elbows. I'll be taping them all latet this summer.
