OT: Rust spots on garage door
Dominic in Bucks County PA
>OK gang, here's where I tap into that great pool of collected knowledge.
My boss here at work has a house down the Jersey Shore. And he has a steel garage door that is rusting. Knowing that I have some experience dealing with rust, he was asking me about rust removers. I told him that there are paints with chemical agents that would convert the rust to a paintable surface and that maybe this would be the way to go. But I'm not sure if this is the right application for that product or not. Does anyone have a reccomendation for a type of paint that is durable enough to use in this application?
However, while my main question is about the type of paint to use, his description of the rust and how it forms got me curious. The rust is worse at the top of the door and gradually lessens as it works it's way down the door. To me this sounds like it has something to do with the way that the sun hits the door. Salt spray is constantly hitting the door. Where the sunlight hits, the door dries out. The worst rust occurs where the water is out of the direct sunlight and allowed to remain on the door longer (like the area near the sill). However, this occurs on ALL sides of this house and others around it. So there are some houses with doors that see more shade than others. But they all have steel doors that exhibit the same rust pattern.
Has anyone run into this before? Is our assumption about the direct sunlight correct (or partially correct)?
Re: OT: Rust spots on garage door
Jesper, Denmark
Re: OT:Plausible......
Jesper, Denmark
>Your conclusion could certainly be correct. The salt spray is not just on the seaward side, but is present as aerosols in the air.
The best way to re-paint is to remove the rust with wire brushing etc. and use a zinc rich primer after cleaning and degreasing. The top coat should be high quality - marine paint would be good, but expensive. Otherwise a PU or Epoxy paint will make a very durable surface.
"Housepaint" just do not cut it!
Metal paints
>Prep is 90%, of course. I would consider the compounds that combine with the rust to form a stable chemistry, after wire brushing and sanding to remove anything loose, and then wire brushing and sanding some more to get as close to shiny as possible.
But even more I'd talk to a professional paint store in his territory about what the best approach is. My experience has been that pro paint folks are always happy to talk to non-professionals who want to do it right. There are paints specifically formulated for metal that are incredibly better than what consumers are sold. My son, who does metal work (as well as general house remodeling), uses these, and the durability is vastly greater. You'll want to have done your deep breathing exercises before they quote the price, lest you faint; but it's worth it. If you need me to do so, I can ask him for brand recommendations - send me an e-mail (but it'll be a few days before I can get back to you, between my schedule and his).
Your hypothesis as to why the pattern is as it is makes sense; it may also be that air circulation will be less at the top, due to the overhang of the trim. To a degree, though, it may not matter; you just need to correct the problem and establish a preventive maintenance schedule.
The other question, of course, is why the builder used a steel door in a marine environment in the first place; but builders are under the gun to get the job finished, and s/he may just have used the solution that came to hand.
Jim DeLaney, Austintown, Ohio
>I'd sand to bare metal - inside and out - then treat the rust with phosphoric acid, rinse, let dry, then coat - again, inside and out - with a marine-grade metal primer followed by a marin-grade paint. Gonna be expensive, though. Check out the Jamestown Distributors website for paint recommendations.
Jim D.
