Question on epoxy?
>I am using some of the epoxy from the borg. I occasionally used the type that came in the two syringes that had twin plungers, help to assure you got equal amounts. This time they did not have any of those, but did have larger squeeze bottles of resin and hardener. My question is, if you err in the amounts, would you lean toward a little extra hardener? Does it matter much? If you have less hardener does it still set, maybe more slowly? This is the 60 minute stuff.
