Bandsaw questions
Bandsaw questions
Bandsaw questions
Tim Johnson
>I currently don't own and have never had a bandsaw. I am looking to purchase one in the next month or so. I am looking at the Grizzly G0513 and G0513X2. Both have excelent reveiw but I just have some questions on the uprades and whether they are worth the money. They are the same machine except the 513X2 comes with cast iron wheels (513 has aluminum), cast iron trunnions (513 is Stamped steel) and roller guide bearings (513 has euro disc guides). The price difference is $200. Is it worth the extra $ for G0513X2? Also what kind of blades should I be using (skip tooth or not, TPI...etc). Mainly i would be using saw for general cutting and some resawing. Thanks for advance for advice. I have never owned a bandsaw so I don't have any experience with this kind of equipment.
Re: Bandsaw questions
Dave's Not Here
>The G0513x2 currently has free shipping so your price difference in only a little over $100. For that little difference the x2 would be my choice.
mdclor
>There are a few books reviewed in the books section of WC that might be helpful. I read Lonnie Bird's The Bandsaw Book before I bought mine. I would say that it was a worthwhile investment.
HTH,
Merle
>I don't have a grizzly bandsaw so I can't directly answer your question. What I do know is that I bought a Delta 14" saw. It turned into a "kit". I added a riser block, and better guides, and a blade release, and better guides, and ..... Now I wish I had a bigger motor.
Buy what you need to start with. I probably have more money and certainly more time in my saw than I would have if I had bought a bigger more powerful saw. Go for it. Get which ever one has the power and features you need.
wilbur
>As far as if the differences that you mentioned are worth it:
Cast iron wheels - yes.
Cast iron trunnions - yes.
Roller guides - maybe.
But the first two are definitely worthwhile upgrades.
blades
Bill Tindall, E.TN
>Can't offer any useful advice to your other questions but we just had the Lenox person in for a program and he talked about setting up a band saw and blades. You want between 3 and 24 teeth in what you are sawing. Hence, you need a variety of blades depending on what you are doing with the saw. I like a 3 tpi 1/2" or 3/4" blade for resawing. But depending on what you need to do some 1/4" blades or 3/8" are desirable. A 3/8" x 6tpi is a versatile blade. Find a local Lenox or Starret supplier that welds up blades from roll stock. Blades for a 14" saw will only be $6 or so. I get mine from Misenheimer in Morristown, TN.
If you saw comes with a handy fence you will find the band saw a nice machine to rip with.
Between 3 and 24 teeth?
wilbur
>Typo, maybe? Even dozukis don't get 24 teeth in a cut very often.
no typo
Bill Tindall, E.TN
>As a recent example from my work.....3 tpi blade because it was all I had, 12" resaw job = 36 teeth in the work. Sawing was very sloooooow because there were too many teeth trying to penetrate the wood. Also saw dust removal becomes a problem.
I think he means....
John in NM
>24 sounds awfully fine for everything but cutting out really thin stock. Even at 1/4" thats six teeth in the cut which seems excessive to me. Personally, I wouldn't think one would ever need much finer than 12 tpi for woodworking, and even that's a stretch.
Re: Between 3 and 24 teeth? *LINK*
Curly Smith
>The charts located at the link illustrate what Bill is talking about.
Band Saw Blade Tooth Selection
Jesse Cloud
>I think Bill's angle here is not teeth per inch, but teeth in the workpiece. When resawing a tall piece, even 3 tpi will wind up having lots of teeth in the wood. That causes heat, friction, and a traffic jam of saw dust trying to get out of the piece.
Bottom line, thinner the blade the tighter curve you can cut, more tpi gives you a smoother cut, but big pieces need fewer tpi - if you are doing a variety of work, you will need a variety of blades.
I also keep a 'utility' blade around to save wear and tear on my pricey blades.
And Amen to Barry's advice too - don't take the kit/upgrade route or you will waste a lot of money, buy what you need now.
Re: no typo
wilbur
>Got it. I wasn't thinking about resaw operations -- mainly curved cuts. The factoid I had remembered is that 3-6 teeth in the cut is ideal, which I guess means that most hobbyist woodworkers will never have an ideal blade for large resaw operations.
Time for someone to market that 1 tpi blade for your Delta 14" bandsaw with a riser. :@)
He means teeth, not tpi
Alex Grigoriev
Riser
Alex Grigoriev
>6" riser kit, unfortunately, compromises the frame rigidity. One significant reason for that is that it uses a long bolt which has to carry all the force. The bolt stretches too much, unless you tighten it really really tight. A better design would call for two short bolts at each end of the riser.
Because of this weakness, when you have to install a wide blade and five it enough tension, all adjustment just goes off.
You're right! Got to read more carefully!
John in NM
Dave Paine
>I bought the Grizzly G0513 a few years ago. At the time the "X" version was not available, even the cast iron fence was not available.
The G0513 was an upgrade from a 15in Grizzly (forget the model).
The G0513 has been a valuable tool. I read the specification of the "X" version. If I did not have experience with the G0513 and was in the market, I may well look closely at the "X" version.
Since I have the G-513, I can only reflect on my experiences with this unit.
I did upgrade to the cast iron fence. To be honest, this was more for the resaw fence which can with the unit. I could have built a wooden equivalent without too much trouble. I also had in mind magnetic attachments. Likely to be created soon.
Between cast iron trunnions, and cast iron wheels, I would favour cast iron trunnions. I have to admit, the G0513 trunnions have not been a problem. Lots of adjustments capabilities, and like most machines, pay attention to initial setup. The machine will be "close" but check since you can likely get "closer".
Whatever machine you purchase, the blades you purchase will make, or break, your experience.
There are many good blades on the market, the selection will depend on what you want to do.
My original blades were Timberwolf. I like these a lot.
I recently wanted to resaw, and was not getting good performance with stock > 3in depth. I purchased a Woodslicer from Highland Hardware and have been impressed with the resaw capabilities.
I would buy the G0513 again, and recommend this to other people, but the machine needs good blades.
I expect a good blade on a less than stellar machine will give better results than a less than good blade on a top line machine.
Compared to the machine cost, blades are inexpensive. Get the best you can afford.
Tim Johnson
>Thanks everyone for their response. It was big help. I will post later what I end up purchasing.
What he said
Walt Smith
>"I expect a good blade on a less than stellar machine will give better results than a less than good blade on a top line machine.
Compared to the machine cost, blades are inexpensive. Get the best you can afford."
The blade does the cutting, not the machine. The saw needs to have adequate power and frame stiffness to properly tension the blade. Will hi buck guides make a blade that wants to cut crooked cut straight? Doubt it if the stock is more than a couple inches thick.
