Jason Young Compound Miter Stand
Henry Higgins
>http://www.woodcentral.com/shots/shot597.shtml
This is the address for Jason Young's compound miter saw stand. The part I am wanting to duplicate is the saw height adjustment.
Here's what I want to change from this plans and will welcome opinions: My sliding compound miter saw has four places where it is bolted to the table. Would anyone in their right mind !!! use the same four bolts to bolt the saw to the table and, below that, for the saw height adjustment?
Using a 3/8" or 1/2" - 5" bolt, from the top down, it would line up like this:
1. hex head bolt
2. rubber washer
3. flat washer
4. 1" miter saw base
5. 3/4" plywood
6. flat washer
7. hex nut
8. about 1" space to make adjustment
9. flat washer
10. hex nut
11. 3/4" plywood
12. flat washer
13. hex nut
14. jam nut
Thanks for looking this over
Re: Jason Young Compound Miter Stand
No problem with your arrangement, except ...
>... one minor inversion of #9 and #10. There are two possible larger issues though that jump out at me. One is getting all the holes lined up, which you could do by either making a drilling template, or just stacking everything in alignment and then drilling through with a portable power drill. The other is the size of the all-thread you intend to use. I would go for a heavy thread, probably 1/2", and I doubt that the holes in the die-cast CMS base are that large, so you'd be enlarging them to accommodate the larger threaded bolts. Maybe not an issue. Another thought is that if you ever decide to use a different saw on this stand, the hole pattern will be different, so you'll have to go through the whole procedure again.
Ellis Walentine, Host
Re: No problem with your arrangement, except ...
Henry Higgins
>Thanks for your review and suggestions!
Re: Just curious
Kneale Brownson..Awaiting return to CO snows
>Why would you want to raise or lower the saw beyond the point where the saw's table is flat with your table extensions? I'd think the system in the sample, or your idea too, would contribute to saw instability.
